So I have nice looking wheels from my other car (Nissan 240sx) that I have been debating on putting on the E34. The nissan lug pattern is 5x114 so I would need to run a lug adapter which they make. The thickness of the spacer is 15mm.
The wheels I have are 3 piece wheels in sizes of:
SET 1: 17x9 ET22 Square
SET 2: 17x8 ET 8 Square
Would these wheels fit with the 15mm spacer? My fenders have been rolled.
I used to run m systems staggered. The rear were 17x9, et22, and I ran them with a 10mm spacer in the rear. non rolled fenders, lots of room. I ran 235/40 on the 9 inch rear.
The fronts were et20, 17x8, with a 20mm spacer, effective et0, and a 215/40. no rubbing on either setup.
Very good chance, pending tire sizes, you will be able to fit them.
Both will fit for sure. With camber plates, even more easily.
But we need pictures, obviously.
I have camber plates.
Then you will be golden. I think you saw my M5 thread, but to reiterate on the H&R springs (540i P/N) and camber plates I was running 9.5" square ET22, with a front 15mm spacer (ET7 real offset), with a WIDE 255/40 and no issues. On I think full right lock (basically only when parking), I would rub the inner fender liner a smidge, but just the plastic part. On the rear with rolled fenders I could have also pulled off a 15mm spacer.
