Results 1 to 7 of 7
Thread: Purchased my first BMW!
    Jan 2017
    Kansas, USA
    1996 BMW 750il
    Hello all!
    After an e46 m3 caught my eye one day a few years back, I knew I needed a bimmer.
    Fast forward and just yesterday I acquired a 1996 750il with 160k mi for $500. It was that price for the reason, engine starts up and idles smooth and healthy sounding but when the the gas is pressed nothing happens. Previous owner said it was due to washing the engine bay with a hose.
    From what I learned just before this impulse buy. Is that you shouldn't buy one of these unless you have money and are a skilled mechanic. Sadly I'm neither.
    Appearance wise it definitely needs some work done to it.
    • Interior is tan and quite dirty.
    • Center console pulled apart.
    • Paint has sun fading.
    • Left headlight has hole in it.
    • All of driver side door/window switches broken.
    • Backseat switches for reclining seat not working.
    • One or more of windows can't move.
    • Rear view mirror fell off/passenger side missing glass.
    My *hope* is to kinda fix it up here and there, and I'll already be thanking you in advance for any advice.
    Will have more pics once it's towed.
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    So it is starts and idles just fine, probably pedal is not responding
    Instagram.com/nordmanmg
    Your current situation is not your final destination
    Dec 2013
    Chicagoland area
    EXOTICS
    Perform a diagnostic scan & post up the codes displayed.
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Sweet deal!
    Sounds like a fault in the throttle pedal sensor system. Will need to diagnose. Some info:
    http://www.meeknet.co.uk/E38/E38_Ele...le_Control.pdf
    You might need some diagnostic software to help with this problem, but it might be worth a shot to try this:
    Quote Originally Posted by BOBS750il View Post
    I've done this a couple times and got it back without using INPA. I turned the key on with the engine off. Pressed the pedal fully down for 5 seconds then let off for 5 seconds. Did that twice then keyed off for 10 seconds. Started the car and all was good. But I would also recommend not resetting the adaptation if it's not necessary.
    Sent from my iPhone5s using BF.com
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Jul 2016
    Chicago, Illinois
    are slow
    -Headlights are cheap as dirt. Get an OE glass set, and the corner of your choice.
    -Part outs will probably get you the center console trim, driver window switches, mirrors, etc but used regulators aren't worth the time.
    -Rear headrests like to break, a lot.
    -If you ever see a Z3 or e36 with the m44, grab its MAF immediately.
    Jul 2015
    Dallas, Texas
    98 750iL, 01 740iL
    i have two very clean xenon headlights from my 1997 750, i'll let 'em go for a good deal, complete- just no bulbs. turn signals, bottom bracket, ballast, rear covers, bulb-fasteners, everything included.
    what color is the car? i've got tons of body parts and stuff laying around i need to get rid of.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    For $500 you really can't go wrong! That's a heck of a deal, especially when you consider how much a 750il was back when it was new. The previous owner may have damaged the two electronic throttle bodies when he washed under the hood, that's the only thing I can think of that would make the gas pedal not respond. The 750il was one of the first drive-by-wire cars out there, so it can be a little finicky.
    1995 525i 5-speed - Thread
  1. Purchased my first BMW, clutch question + more
    By Funez in forum 1991 - 1999 (E36)
    Last Post: 07-13-2007, 02:09 PM
  2. Need Advice Purchasing My First BMW!
    By Ebonyisland in forum 1999 - 2006 (E46)
    Last Post: 01-31-2007, 05:17 PM
  3. Looking to purchase my first BMW
    By dusty540 in forum 1996 - 2003 (E39)
    Last Post: 11-15-2006, 06:48 PM
  4. About to purchase my first BMW and have ?'s
    By LT1PnyKlr in forum 1999 - 2006 (E46)
    Last Post: 07-21-2005, 11:25 PM
  5. About to purchase my first BMW and have ?'s
    By LT1PnyKlr in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-21-2005, 01:00 PM
