I went bottom mount for sleeper status. I love that you can't see the turbo with the hood open. Can't wait to use the old "It's just a lightly modded S52, wanna do some pulls?"
does the intercooler in the front not give it away? otherwise I would say total sleeper!
My intercooler is anodized black. I like the sleeper look and have a bottom mount. But if you like the bling, top mount is the way to go. One does not perform better than the other, neither is easier to install, and there are advantages and disadvantages to both. Think about things like gravity drain or scavenge pump, open or twinscroll, above subframe or under subframe hotside piping, room for a proper intake, room to maintain the AC with reasonable hotside piping, engine bay heat, etc.
what size of down pipe are most people running with a top mount? 3" or 3.5"?
is there a noticeable difference between open and twinscroll?
That first car sounds dope .. I want to build my e36/328 Vert into a turbo car
http://www.bmwmregistry.com/detail.php?id=13792
* E39 M5 SterlingGray -RIP 11/2018
* E36 328 vert Schwarz - ~TurboProject underway
* E90 335i Sedan MonocoBlau - Daily ToddlerTaxi
Once people start installing their new Steedspeed manifolds there will be some really good turbos and manifolds up for sale.
You won't see the intercooler, just the rear bumper, hopefully. I've been thinking of ways to make the intercooler less conspicuous, painting it black seems to be the best / cheapest / only idea. i'm on the fence on painting it.... There's only so much one can do to maintain sleeper status without going to great lengths. I'll do as much as i can that's within reason (bottom mount,WG recirc pipe, limited gauges and gauge placement, "quiet" exhaust), but something can't be hidden without going thru great lengths. It's hard to hid a 3.5" exhaust and a big honking intercooler.
My intercooler is also black. My exhaust is 3.5" goes into a muffler with dual 2.5" tips that match a stock muffler. One of the tips is blocked off until I get to 6 psi of boost then a wastegate actuator opens a butterfly valve. It's pretty quiet when cruising, not so much when at WOT. It's stealthy.
I'll be painting my intercooler black but just the solid bars not the through fins.
I like that muffler set up a lot too! If i wasn't running dual 3.5" single in/out mufflers, i'd probably do something similar.
I don't have the need to have a loud car and have spent a lot of time trying to do what I can to have it as quiet as possible without having back pressure. This muffler is really quiet when cruising, I hear tire and engine noise over the exhaust. At WOT, it's a good tone and not too loud but at the track, due to the pitch of the sound, it exceeds the noise limits. I needed to find a solution so I have a straight through 3.5" muffler that is much louder but the tone is deeper and passes the dB test. I put a V-band at the mufflers inlet so it only takes a couple of minutes to swap them.
This x1000000. Before even approaching butters and speaking to Greg I set a goal for my car and knew what I wanted and how I wanted it done. I had the major components already bought and just needed some guidance from butters on a few things like bov, fpr and stuff like that. If you don't have specific goals set you're going to want to chase what other people are doing and upgrading to and never finish.
