Originally Posted by
LockDots
Well, your question was "Can you power the head unit with a bench top power supply". Yes, you can, so long as it can source the current the radio needs. For example, if the power supply can only supply 1A of current but the radio draws 5A when on, then the power supply will either fold back or become damaged from the excessive load. Most bench top power supplies today will simply fold back, or shut off to prevent damage.
As for the security features of the radio, the only way to know for sure is to either disconnect the radio from the car momentarily and reconnect to see if it asks you for a code, or disconnect the battery from the car momentarily. Either way you're removing the constant 12V feed to the radio which is what retains memory.
