Does anyone know how to fix a dented valance? Since its fiberglass, i'm not sure how to fix it.
Got a picture you can post?
Dean
Lutz, FL
'85 635 CSi Euro #9402254
'87 Spider Veloce
'92 Spider Veloce
'08 350Z
front valence under bumper? Its plastic, not fiberglass. If broken, my best results have been with backer plates attached with small rivets to reinforce a plastic weld or plastic epoxy joint. I made plates out of sheet aluminum I had lying around. Once glued, you can sand down rivet heads on the front a little then apply a thin coat of bondo. You'll never know its there and repair will be super strong.
Since the part is plastic, you may be able to carefully reform it using a heat gun on a low to moderate temp setting. However, the paint is likely not as heat-tolerant as the plastic material the spoiler is made of.
Dean
Lutz, FL
'87 Spider Veloce
'92 Spider Veloce
'08 350Z
My valance has a piece of flat bar up in the top of the fog lamp hole and bolted up through the valance to the bumper to pull it up tight to the bumper. If you hit something with the bumper it probably would get damage but I'll take that chance
youtube has plenty of vids on fibreglass repairs to spoilers and valances. Give it a shot. Does not look too hard.
1977 633 CSi RHD Euro. S38B38 3.9L M5 Transplant. 5 Speed Getrag Dogleg. 3.73 LSD. 417hp, 369lb/ft
1971 3.0CS E3 2dr Alpina Special Coupe Racer, 347hp, 295lb/ft
Mine was deformed on the passenger side like yours is on both sides. The valance is very flexible, I just drilled through and added an additional nut and bolt, pulled it up tight, no problems adding the bolt and it looks fine now.
SprCpe
1989 635csi # 3268410
Built in Germany with love.
Ostatecznym maszyny jazdy BMW
I don't have a before picture, I can show you how it looks now.
yeah can i see it now?
SprCpe
