Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 3 of 3
Thread: e36 wheel fitment help
    Apr 2016
    missouri
    2015 gmc canyon sle
    Currently running 17x9 et25 with 245/40 tires all around. The front rubs the fender liner at full turn like going into a parking spot and the rears rub the fenders themselves when cornering hard. I've replaced all the suspension with oem replacement. My question is would running the same tires on an 8" wide wheel with a higher offset resolve this or can I run a smaller tire (215/40/17) I know it will look stretched but I really like my wheels. I don't want to pull the fenders if I can help it.
    Nov 2013
    Stone Ridge, VA
    1995 BMW M3 Coupe
    245/40 on a 17x9 is perfect. Don't run 215/40, way too small of a diameter.
    If you like your wheels why would changing to an 8" wide wheel be an option?
    I would definitely, 100% have your fenders rolled professionally. It will be the cheapest option and if you're only rubbing at full lock or hard cornering then rolling would solve this.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Some negative camber can also help. I agree with not running the 215 tires. You could try a 235/40R17 and the negative camber.
    If I can help let me know.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
  1. E36 Wheel fitment. Need help + advice
    By Alexcoit in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-18-2015, 04:08 PM
  2. e36 2dr Wheel fitment help needed
    By Camoflash in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-13-2006, 12:36 PM
  3. e36 wheel fitment
    By russde in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-12-2004, 08:31 PM
  4. '98 Z3 Wheel fitment....HELP!!!
    By ///MCubed in forum Z3 (E36/7, E36/8)
    Last Post: 12-08-2003, 05:00 PM
  5. Wheel Fitment Help
    By uberpanzer in forum 1983 - 1991 (E30)
    Last Post: 08-01-2003, 12:55 AM
