Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 15 of 15
Thread: ► APEX | 17" ARC-8 Group Buy 2017 (Round 1) — Up to $150 off a set!
    California BAY AREA
    e30 M3, 335d
    This Group Buy has ENDED
    This Group Buy has ended!
    Click the link in our signature for our most recent promotions or Group Buys. To stay up to date and never miss another Group Buy, promotion or any other APEX related news, just simply visit our website here!
    California BAY AREA
    e30 M3, 335d
    We have 42 members interested so far! Lets keep the momentum going!
    California BAY AREA
    e30 M3, 335d
    Sign up today and save big on a set of 17" ARC-8 wheels!
    California BAY AREA
    e30 M3, 335d
    Shown on the Hellrot E36 M3 is the 17x9” ET42 ARC-8’s wrapped in 245/40/17 street tires with a 12mm spacer in the front. The 17x9" ET42 is a wheel that can accommodate the wider 245/40/17 R-compound tires and also 255/40/17 street tire size because of it's greater width. A 12mm front wheel spacer is needed to clear the front strut.
    California BAY AREA
    e30 M3, 335d
    Need wheels for the upcoming track season? Then this is the Group Buy you! You don't want to miss out on this amazing deal!
    For those looking for a staggered fitment that allows for staggered face profiles eor add big brake clearance, the combination of 17x8.5” ET40 and 17x9.5” ET35 is a very popular choice for these applications. The 17x8.5" ET40 is a direct fitment for your E36 and would not need any additional negative camber, wheel spacers, or fender rolling when using a 235/40/17 street tire. The rear fenders do need to be rolled but not pulled for the 17x9.5” ET35 wheel, when in use with a 245/40/17 tire size.
    Dec 2011
    Glendale, CA
    01 M5, 99 M3 Turbo, Z3M
    Gentlemen, I'm very interested in a set of 17" ARC-8's, but I need to verify if they'll clear my BBK. My fronts are Brembo 355x32 and rears are 328x28.
    Can someone help please?
    Thanks,
    Arty
    [img]https://s1.postimg.org/2m3uctoxzz/IMG_2420.jpg[/img]
    1999 M3: RK Tunes, E85,
    GTX3582r: 585whp/608wtq @18psi
    2001 M5: Imola Red on Imola Red Interior, Evolve Alpha N Tune, IATS Relocation, AFE Dry Element Drop Ins, Dinan Front Strut Bar, Dinan Rear Swaybar, Dinan Springs and Koni Sports, Rogue SSK and Transmission Mounts
    California BAY AREA
    e30 M3, 335d
    Quote Originally Posted by TechnoViolin View Post
    Thanks,
    Arty
    Hi Arty! Appreciate the questions. What chassis would these wheels be for and are you running the 4-piston or 6-piston 355 kit?
    -Matt
    This Group Buy enters the payment phase in just 2 days! You don't want to miss out on this opportunity!
    The 17x9.5" ET35 ARC-8's are the most aggressive 17" wheel set up available for your E36 M3. Because of the wheel's concavity, it is most commonly used as a street fitment with undersized and stretched sidewall 245/40/17 street tires as shown on the photo above. The 17x9.5" ET35 requires a 5mm spacer up front to clear the suspension. Even with the 5mm wheel spacer, proper spring perch location with coilovers is very important. The required camber in front to clear this fitment would be at least -3 degrees. Camber plates are recommended for this reason. The rear fenders are the trickiest part of the 17x9.5” concave fitment: the rear fenders need to be rolled but will not need to be pulled if used with a 245/40/17 street tire. Any tire wider will require more fender work such as “pulling”. Our best advice is to focus extra attention in this particular spot when rolling/pulling fenders. Added negative camber in the rear will help with tire to fender clearance as well, so we suggest around -1.8 to -2 degrees, which is much easier to set with aftermarket adjustable lower control arms.
    Dec 2011
    Glendale, CA
    E36 M3 coupe, 4 piston
    California BAY AREA
    e30 M3, 335d
    Our 17x8.5 ET30 and 17x9 ET42 will not clear. The 17x9 ET30 can technically work with a 12mm spacer, but that would be an extremely aggressive fitment and not ideal for the front of an E36 M3. For better brake clearance, you may want to consider our 18" options
    -Matt
    This Group Buy has now entered the payment phase. Pledge today and save big on a set of 17" ARC-8 wheels!
    California BAY AREA
    e30 M3, 335d
    Hello Everyone,
    There are 2 days left on the clock for the 17” ARC-8 Group Buy. We currently have pledges for 40 sets of wheels, which represents ⅓ of the 101 members who indicated they were interested during the feeler phase.
    We typically see a rush of buyers in the last few days of every Group Buy, but there is no reason to wait as the system does not reward those watching the deal and joining at the last moment. Submit your pledge today and save big on a set of 17” ARC-8 wheels.
    The Group Buy ends on 02/09/2017 at 11:59PM PST - let's finish strong!
    -The APEX Team
    May 2013
    Rancho Mirage, CA
    1996 BMW 328i Convertibl
    Pledged.
    Mar 2013
    Upstate NY
    M3
    I have the et30 17X9 with 12mm spacer and with -2.7 camber it just barely fits the car any more and it would need fender work. I'm running st coils and lowered and it fits 245 40 pss tires but I had to trim the inner fender liner. Hopes this helps anyone that's wondering. (I'm hoping 345mm brakes fit as well)
    -2.7 on front and -1.5 rear its slightly aggressive for a normal person but I drive hard mountain roads so it helps.
    May 2013
    Rancho Mirage, CA
    Quote Originally Posted by Mklock View Post
    I have the et30 17X9 with 12mm spacer and with -2.7 camber it just barely fits the car any more and it would need fender work. I'm running st coils and lowered and it fits 245 40 pss tires but I had to trim the inner fender liner. Hopes this helps anyone that's wondering. (I'm hoping 345mm brakes fit as well)-2.7 on front and -1.5 rear its slightly aggressive for a normal person but I drive hard mountain roads so it helps.
    Any pictures? I put in an order for the 17x9 ET30 Hyper Black and I'm curious to see more pictures of that fitment. Also was the 12mm spacer necessary? The Apex rep I discussed with told me a front spacer is not required. However rolling the rear fender is.
    California BAY AREA
    e30 M3, 335d
    Quote Originally Posted by ursuscalifornia View Post
    The 12mm spacer will not be necessary up front with the 17x9 ET30 wheels. This fitment is a direct fit up front, but a fender roll would be required in the rear. If you were to run the 17x9.5 ET35 up front, then a 12mm spacer would be needed.
    -Matt
    Alright ladies and gentleman, we are down to the final hours of the 17” ARC-8 Group Buy and have 54 members pledged so far! Lets keep the momentum going and finish this Group Buy strong!
    The Group Buy ends tonight at 11:59 PM PST - It’s crunch time!
    -Matt
    Mar 2013
    Upstate NY
    M3
    Best I can do, I only run spacers to clear ST Coilovers (KW)
    A slight fender roll in back is needed if you are looking to lower it from stock height.
    With the tire I think they are like 37 pounds which is crazy lol super light setup.
  1. ► APEX | 18" EC-7 Group Buy 2017 (Round 1) — Up to $200 off a set!
    By Eddy@ApexRaceParts in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-09-2017, 05:58 PM
  2. ► APEX | 18" EC-7 Group Buy 2017 (Round 1) — Up to $200 off a set!
    By Eddy@ApexRaceParts in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 02-09-2017, 05:57 PM
  3. ► APEX | 17" ARC-8 Group Buy 2016 (Round 2) — Up to $150 off a set!
    Last Post: 07-08-2016, 01:28 PM
  4. ► APEX | 17" ARC-8 Group Buy 2016 (Round 2) — Up to $150 off a set!
    Last Post: 06-23-2016, 02:48 PM
  5. ► APEX | 17" ARC-8 Group Buy 2016 (Round 2) — Up to $150 off a set!
    By Eddy@ApexRaceParts in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-23-2016, 01:58 PM
