Page 1 of 70 12345678910112651 ... LastLast
Results 1 to 25 of 1742
Thread: 2017 what did you do to your e38 today?
    Jun 2013
    Toronto, Ontario
    '95 740i
    Question 2017 what did you do to your e38 today?
    Patted it on the back! Poor girl has to sleep outside all winter in the garage until I can get back to work on her in the spring! Sleep well =D
    || 1995 740i || M60B40 || DUDMD || ̶o̶r̶i̶e̶n̶t̶ ̶b̶l̶u̶e̶ Mercedes Brilliant Blue Metallic || Style 168 Wheels 1" Spacers ||
    Everett, WA, USA
    '01 740i, '93 300ZX TT
    Ordered front/rear stealth amber bulbs from Bimmian, along with a 4" MAF and rear window spoiler. Goals for this year include new door speakers (likely from Bavsound), between a 40-50% tint, and a tune by DUDMD. Then she's done.
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Quote Originally Posted by PiotrC70 View Post
    They are never done...... maybe just suspended automation.
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    Need to buy a 295/25/21 Michelin Sport tire....I have to find 1 used with at least 80 % tread.... Been on my Alpina front spare wheel on the back for 1 month now...It drives awkward
    2000 740i Sport
    Everett, WA, USA
    Quote Originally Posted by TxDarth View Post
    Well yeah... but she'll be like 99.9% done. My goals with her were never grand to begin with, that's what my Z32 was for. Unless I'm able to score a deal on a supercharger, I don't see myself going down the route of modding for power.
    Aug 2015
    Oconomowoc, Wisconsin
    01 750il, E38/9 Parts
    Well it has been a long few days indeed. Started with what I thought was a coil died on me about 40 miles from my house, misfire and knock codes and the like, and naturally on cylinder 4. Get it home, swap a newer known good coil from my e39, problem persists. Pull the plug, had an absolutely massive gap, causing no spark whatsoever, which leads me to believe they are the original plugs in the engine, being that it has about 70k miles on it and coils are all dated December '96 (donor car for the engine/trans was a '97). Anyway, I have 8 NGK iridium plugs that I will swap in later tonight, at the moment I is on one of my e39 plugs.
    I've had a 55-60 mph shake for a while, and kept putting it off because its cold outside and I work most days. Finally start doing it, Got the first bushing out and a new one in (I went powerflex) in about 45 minutes using a pulley puller borrowed from work, no issues at all. Jump forward 4 hours and the passenger side is still in the control arm, hasn't budged and is significantly more mangled. Well, I need to drive to work tomorrow so that had to go back into the car as is. Even with one bad bushing, there was a very noticeable improvement on how the car drives, and I'm looking forward to it feeling like a 7 series once again. Anyway, the grease boot was torn on that one anyway, so I think I will order a new one or pop by the scrap yard and see if a decent one is available, and then press the old bushing out correctly.
    I also found out something fun with the brakes which pisses me off, but its hard to explain without seeing it, so I will once the video gets uploaded to youtube.
    Alright, here are the brakes, sorry for the shaky video. The hole where the retaining bolt goes has managed to shear itself of, so the rotor is just sitting there held on by the wheel bolts, which sucks because the rotors have a lot of life left in them.
    --- 750il Maintenance/Restoration Thread --- E38/9 Parts Cars --- YouTube Channel ---
    Aug 2011
    Vancouver, BC
    1998 750iL Individual
    Ice drifting!
    Own an E38? Add it to the E38 Registry!
    http://www.e38registry.org/
    Mar 2004
    Tyler, Tx
    That will not hurt anything - that bolt just hold the rotor in place while the wheel is off - once the wheel is back on it serves no purpose.
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    Lubed up the seat belts with silicone spray, they fly back in now. Easy!
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    Quote Originally Posted by acspecialists View Post
    hate to tell you the truth why seat belts do NOT retract back...Its because of DIRT/ SWEAT... Try Cleaning the seat belts with warm soap and sponge...I noticed mine was getting stiffer why? I would play bball at gym and right after games take off home...I then realized the seat belts weren't retracting like they used to They were stiff like ...So I Cleaned them and now they are soft , flexible and retract like new...
    2000 740i Sport
    Aug 2015
    That's good to know, although I think I will replace it just for my own peace of mind
    Sent from my Nexus 6P using Tapatalk
    Mar 2004
    Tyler, Tx
    Quote Originally Posted by ColtonBH View Post
    Agreed I would definitely replace at your convenience but I would drive in the meantime .
    Bonita Springs, FL
    01 740i, 09 X5, 12 335i
    Put the car cover on today after driving it with our unseasonably warm weather. Winter looks like it is on the way later this week, so the nap has begun.
    2001 740i Sport - Anthracite Metallic, Gray Interior, 750 Porn Lights, 750 Seat Backs, Hoen Xenon-match Fogs, Crossed drilled, slotted rotors, LED Interior Swap.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Going to sticky this thread up top to avoid duplicates.
    McKean township Pennsylva
    1999 M3 , 1999 328is
    Parked the e38 outside to paint in the garage. It's a balmy 40 degrees here anyway.
    The e38 was lucky and got a bath on Christmas day to wash all of the road salt and cinders off.
    Current fleet:
    1999 BMW e36 M3
    1999 BMW e36 328is with rotary valve engine head
    1999 Oldsmobile Eighty Eight
    1990 Jeep Comanche Eliminator
    1962 Austin Healey Sprite
    Oct 2014
    NE
    2000 740IL
    yup one of my fronts is gone and i ran an e38 for some miles with no rear screws and it was fine. caliper and wheel hold em on just fone
    Quote Originally Posted by cazal740i View Post
    what are you sweating out bro lmfao
    Aug 2015
    california
    1996 BMW 740il
    Painted my valve covers wrinkle black, collected parts for a cooling system over haul, purchased valve cover gaskets which will be installed with the newly painted valve covers took her for a wash
    Aug 2015
    Quote Originally Posted by Bmindt View Post
    Pics please!
    I've been drinking, uh, I mean thinking...
    Seriously though, I want an exhaust on the 7, and am fully considering something like this.
    Jul 2016
    San Diego
    1998 E38 750iL
    Pics please!
    I've been thinking similar thoughts, but rather the cutout would go in the sides of the rear bumper. With my muffler delete, the pipes are already pointing that way (if the bolt-on downturns were removed).
    Dec 2015
    Charleston, SC
    Z3M
    Put on a pair of 275/35/19 Continental extreme contact DW tires in the rear. So far so good. I have a new alpina lip on the way to replace my current cracked one. Bought a new set of gloss black kidney grilles to replace my faded set, and I'm thinking about getting another set of headlight washers just to freshen up all of the front end.
    2011 Mercedes e550
    1998 Z3M roadster
    1999 Z3 2.3 roadster
    2001 750iL Sport
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Quote Originally Posted by RDE38 View Post
    I'll buy your nasty old ones if you do!
    I replaced front sway bar links and bushings, and also the broken, deformed front fender liners and lower coverings right behind the fenders.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Jan 2013
    California
    2001 E38 iL
    Pics please!
    Probably the dumbest place to have your exhaust exit. Your rear passengers would kill you, then die.
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    Quote Originally Posted by Raudi Driver View Post
    Brilliant
    Instagram.com/nordmanmg
    Your current situation is not your final destination
    Aug 2015
    Hah, well I guess I stick to the original plan of only doing that on the e39. One of the reasons for doing it is that it would leave me more room to build a hitch on the e38, a nice hefty one so that I can tow the e39 around.
    Kansas City, MO
    2x01 750, 01 740
    I was wondering if you saw the pics in here... http://www.bimmerforums.com/forum/sh...anual-with-LSD
    See my E38 parts for sale on eBay: click here!
    PM me here for a 5% discount on any of them!
  1. 2016 what did you do to your e38 today?
    By 1badturboe38 in forum 1995 - 2001 (E38)
    Last Post: 01-01-2017, 07:03 PM
  2. 2015 What did you do to your E38 today?
    By Mayorchuck in forum 1995 - 2001 (E38)
    Last Post: 01-06-2016, 03:36 PM
  3. 2014 What did you do to your E38 today?
    Last Post: 01-01-2015, 03:13 PM
  4. What did you do to your E38 today???
    By kooljess in forum 1995 - 2001 (E38)
    Last Post: 01-30-2014, 12:28 AM
  5. What did you do to your E36 today?
    By Eurodriver in forum 1991 - 1999 (E36)
    Last Post: 01-09-2008, 08:54 PM
