Results 1 to 2 of 2
Thread: BNIB Full-Race 4 Port Boost Control Solenoid - No Longer Available
    Jan 2005
    Santa clara,CA
    F80
    I have a BNIB Full-Race 4 Port Boost Control Solenoid for sale.
    Our 4-port boost control solenoid valve is designed for use in applications which target a clearly defined boost curve. Capable of improved boost response and in some cases with a soft WG spring ? quicker spool The 4-port design works equally well in low boost applications as high boost. This differs from a traditional 3-port BCSV because it precisely directs pressure to the open and close ports of your waste-gate diaphragm. This allows much lower waste-gate spring pressure for better low gear boost control and perfect high gear, high boost control.
    Full-Race 4 Port Boost Control Solenoid Features:
    A soft waste-gate spring will enable much higher boost levels
    Better spool-up and mid range power
    Better duty cycle control
    Solenoid is normally closed so that on failure you will run off the waste-gate spring only ? to prevent over-boosting.
    1/8th NPT fittings, easily adapted to AN fittings.
    Full-Race 4 Port Boost Control Solenoid Compatibility:
    Ideal for use in sealed Dual Port Internal WG applications, Internal or External
    Hondata S300, K-Pro or Flashpro
    Cobb Tuning AcessPort
    All PWM modulated standalone and piggyback ECU?s will support this 4 port BCSV!
    Price is $50 shipped Cont USA + PP fees if not using the FF option OBO.
    NO Panjo payment. Payment through PayPal
    List Date: 12/27/2016
    For more info, click here to view the original listing: BNIB Full-Race 4 Port Boost Control Solenoid
    This item is no longer available.
    Jan 2005
    Santa clara,CA
    F80
    up
  1. Replies: 38
    Last Post: 12-12-2012, 10:45 AM
  2. Greddy boost controller solenoid
    By Krank in forum Forced Induction
    Last Post: 01-11-2009, 05:50 PM
  3. FS: AEM Electronic Boost Control/Solenoid
    By m52 E30 in forum Race Cars & Track Parts
    Last Post: 05-30-2007, 11:50 PM
  4. AEM vs. GM Boost Control Solenoid
    By Rob 99 M3 in forum Forced Induction
    Last Post: 12-18-2006, 02:23 AM
  5. Electronic boost control solenoid is bad (I think)
    By S0nik in forum Forced Induction
    Last Post: 07-11-2006, 05:58 PM
