I didn't undo the hoses from the fuel lines under the manifold. All I did was remove the bracket securing them onto the manifold.
Curious ..... I no longer hear the fuel pump.... the pump and relay are both new. I also checked the fuel pump fuse and it is good also. Stumped as to the issue.....
Crank sensor not plugged into the correct connector?
demet
I think I might have found the problem.
just tested the ignition coil. No spark.
I cant wait to see how it is, I'm looking to do these as well soon.
Herr, wirf Hirn vom Himmel! ... oder Steine, Hauptsache er trifft.
88 Alpineweiss / black E30 M3 -Project.
Brilliantrot / black US SPEC 3/90 prod e34 M30b35 535i 5spd - Modded.
98.5 Tiag Silber /black e36 m3 - Modded.
99.5 Estoril Blau /dove e36 m3 - Modded.
07 Crimsonrot /black E83 X3 6spd - Stock..
So I installed a new ignition coil and it fired up. But now the engine sounds horrible.
Thoughts?
*link to vid below*
Maybe you incorrectly inserted plug on the coil?
BTW, I don't if it's just me, but I'm not hearing sound on your video.
My apologies. It played the first time after I uploaded it. I'll try rehosting it.
http://sendvid.com/yk8t93u2
stop test pulls up 1222 lambada control 1.
My car had a similar issue when I had 2 completely fuxored motor mounts. Sounded almost exactly the same and it would die out on me. I changed the fuel filter, plugs, dist cap and rotor. As it turns out after several big bumps I had knocked some electrical clips loose that clip in to the injectors. The ones pictured below. Take the cover off and make sure to press firmly down so you know they are connected to the injectors.
any updates ?
You either learn the easy way or the hard way.. looks like he learned the hard way.. at least your son is okay.
