Anybody got a recommandations for a quality handbrake with "parking function" found on the cheap ebay ones?
Must have wilwood cylinder.
the only ones i've ever seen are ebay junk
if you want something that'll pretty much work the same, i suggest buying your handbrake of choice + this
https://www.summitracing.com/parts/a...FRdMDQodJEQBog
or something similar. it's what i used on my e30 when i had a standalone handle. simply apply pressure to your brake pedal, close the valve, and boom - your car won't move. i never had any issues with it leaking pressure in the 1-2 years i had it installed on my e30. just make sure all your lines & fittings are in order because as soon as the lines leak and the car is parked on a hill and not in gear for some reason, you're about to have a really bad day
Popular engine swap weights & stock engine weights
M42 + trans - 427lbs
302 + t5 trans - 475lbs
m20b27 + g260 - 497lbs
m52b25 vanos + g250 - 544lbs
351w + t5 trans - 572.5lbs
LS, aluminum block + t56 - 609lbs
LS, iron block + t56 - 719lbs, EST.
http://www.bimmerforums.com/forum/sh...60-m42-1jz-2jz
I use this one, it was highly recommended by the Rally shop that installed my roll cage.
http://www.ebay.co.uk/itm/APS-470mm-...-/301699309139
It's not a wilwood master though
That's a nice looking handbrake!
If you can wait until early 2017, we just ordered the metal for this: handbrake render.png
Working on releasing as many new products as possible in the next 12months
That's a bad piece of equipment right there! I guess it will be out of my price range (deservedly), but it looks sweet.
That looks nice. Where is the price going to land on that one?
And what else is coming up?
Weight!! Haha, actually when I full M3 rear swap in my 328 I didn't have the M3 calipers and my 328 rotors wouldn't fit so I ripped it all out, including cutting off the shoe-seat where the cable comes through the TA. Basically I can't ever reinstall a drum parking brake lol, and yea it was annoying the next time I went to park the car. Oh well, making Colin Chapman happy haha
Wow, I haven't seen a Colin Chapman reference in a while! Lol
k-sport makes a hydro with a locking mechanism sort of thing. There are also cheap $30 shipped knockoffs on alibaba or aliexpress. if you get smart, you can actually buy one of those, of aliexpress then replace the master with a wilwood master and you have a really good piece for around $100. i havent done anything with mine yet, but a buddy has the aliexpress knock off k-sport on his 2jz s13 and he rips. no complaints from him.
I find that the stock one works really well with an extension added onto it. It locks up better than 3 of my friends hydros do and is certainly cheaper. I also really like being able to still use the footbrake while handbraking. There are situations where you want to get closer to an inner clipping point and can only maintain angle while doing so while braking and handbraking at the same time. The only way I would go hydro is If I went dual caliper rear. Yet my brother has an ASD with dual caliper rears and it still doesn't lock up as well as mine. I'm sure if he swapped the calipers of pads out he could help this but it sure is a lot of work and money when you can just add a whammy bar to your stock ebrake and just adjust it occasionally.
If the hydro does not lock up better then the stock rubbish, there is something seriously wrong.
Not saying the stock cant be made to work ok, but I hate the whole system.
I just installed the massive brakes adapter, and wilwood calipers.
But on my previous car I had a inline hydro that worked qoneders, no problem brakeing and handbrakeing and the same time.
How do you like the massive kit? were you able to retain abs or the stock parking brake?
Have you worn out the stock shoes before? How long did it take you? I've been going on my stock shoes for 2 seasons and havn't had any issues. Typically drum brakes (what e36s use for a ebrake) last a very long time. I have a van with 185k on it with the factory shoes still on the rear.
