Results 26 to 50 of 52
Thread: ///dean's turbo build and dyno thread (GT35R/E85/Stock Comp)
  1. #26
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Love this build. Mine's alpine white as well. Hopefully one day it'll make nice responsive numbers like that.
    Quote Originally Posted by bmmrr View Post
    Need more instagram accounts to follow from binmerforums users. Wanna see the beasts in action.
    i'll follow you right now as well.
  2. #27
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Such an awesome power band! I'd love to see how this set-up would be at say 11.5:1 CR and 18psi. My 11.2:1 s52 made more torque earlier and was much more responsive than the stock CR s52 in my Ti with the same mods now, I can only imagine with 100% e85 and your turbo set-up!
  3. #28
    Jun 2006
    San Jose, CA
    98 AW M3/2/5
    Just started to realize there is an abrupt dropoff in power and torque up top of the 610whp dunk run. You can see in the sheet I've posted around 6800-6900 the dip. The logs show no let up on throttle with AFR/IAT/FP also being ok.
    Is this a sign my setup could be maxing out? If so, what component?
    I'm running a GT35R, SPA T3, 3" exhaust, 485 FP, 115lb injectors, E85 tune.
  4. #29
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    From the dyno on the first page it looks like the turbo is out of efficiency range.
  5. #30
    Jun 2006
    San Jose, CA
    98 AW M3/2/5
    Quote Originally Posted by E36 HateR View Post
    Post #17 ? The dyno sheet in my first post #1 seems fine.
    2006 CB M3/2/SMG
    1998 AW M3/2/GT35R
  6. #31
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Ahh i see it now, hmm im not sure looks like the turbo is running iut of breath but that drop seems weird.
  7. #32
    Apr 2006
    Minnesota eh?
    86 325es
    Thats what it looks like when a pushrod V8 floats the valves but that doesn't make sense on an S52. I wonder if it was pulling timing.
  8. #33
    Toronto, Canada
    E36 Turbo
    The dip is probably the operator letting off slightly to not hit the limiter...
    If not then it's probably an air flow restriction or timing pull (maybe MAF is maxed out?)
  9. #34
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    If it was pulling timing i would expect the power curve to not be as smooth, correct?
  10. #35
    Manchester, N.H.
    96 332IS 6466 turbo
    3" intake and 3" exhaust combined with a t3 gt35r. Your doing well with that combo.
    Your at the limit of all if it.
    Remember air pump, a 3.5" intake will help greatly, so would a 3.5 exhaust. But I wouldn't expect too much more out of it. That system is designed to be a 500-550 whp solid kit. Your 50+ what most people get out of that system.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  11. #36
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I think you are doing great in terms of power and would not worry about the slight drop at the very top of 4th unless your logs show something to worry about like a lean condition. Very good power for a spa with gt35r and 3 inch in/out. The E85 is helping. You are making your goals, so even if the turbo is about done, that is fine. With a 4 inch intake and 3.5 inch exhaust and gt35r, I had almost identical numbers (607/580 DJ SAE) on 93 pump plus meth at 21 psi, and thought the turbo was about done since going to 22 psi added only 2 rwhp.
  12. #37
    Jun 2006
    San Jose, CA
    98 AW M3/2/5
    Quote Originally Posted by NOTORIOUS VR View Post
    My first thought as well but after checking my Zeitronix logs, the operator definitely went past 7k as he did w/ the other 2 runs.
    Quote Originally Posted by Butters Stoch View Post
    Thanks for the encouraging words. I'm definitely happy w/ my current results and not looking for more power. The only ask was for future reference as I will have a fully built motor on hand and plan to use my existing components to see if there is anymore left on the table. It sounds like I'm maxed out and will need at least a 3.5" upgrade (intake/exhaust) to benefit from boost increase.
    2006 CB M3/2/SMG
    1998 AW M3/2/GT35R
  13. #38
    Aug 2016
    Chicago, IL
    BMW 328i Turbo
    Just followed on IG. Is that a crank case pressure gauge I see in there? Clean engine compartment, love it.
    1997 BMW 328i Avus Blue - S52B32 Motor - VAC 140 MLS HG - ARP Head Studs - Supertech Inconel/SS Valves w/ 80# Springs - Standalone Megasquirt 3 - CX Racing Turbo Kit - E85 - Wally 485 Fuel Pump - 80# Injectors - 6 Puck Sprung Clutch - Lightweight Flywheel - Stewart Pump - Mishimoto Z3M Radiator & Expansion Tank & Electric Fan - H&R Cup Kit
    Support my hobby by supporting my business! (myeasytek.com) - Follow me on Insta: @realjtbabin
    15PSI @3700 RPM - 488 WHP, 481 WTQ @ 4600 RPM
  14. #39
    Jun 2006
    San Jose, CA
    98 AW M3/2/5
    Quote Originally Posted by jbabin87 View Post
    Thanks for tbhe compliment, I think you maybe referring to the mechanical gauge mounted in the FPR. I don't have a CC psi gauge.
    2006 CB M3/2/SMG
    1998 AW M3/2/GT35R
  15. #40
    Apr 2008
    Bay Area, California
    01M5, 99M3 Supercharged
    Sup man! _m3gusta from IG here.
    Super huge fan of your build. I'm glad you're posting on BFC so we can get some more information. Like someone else said I kind of had the same build planned out but your results pushed me over the edge some time last year. Still collecting all the parts but I can't wait to get the build started.
    We're local too - we should hook up sometime. Maybe show up to a car meet with a combined 1300WHP
  16. #41
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    What fuel lines are you running ?
  17. #42
    Jun 2006
    San Jose, CA
    98 AW M3/2/5
    Quote Originally Posted by illmatik View Post
    Definitely, hope to make it out sometime.
    Quote Originally Posted by rajicase View Post
    Stock fuel lines but different Fuel pump, injectors, FPR, and Rally Road rail and Racetronix fuel pump harness. I may upgrade the lines one day but so far stock has been fine.
    2006 CB M3/2/SMG
    1998 AW M3/2/GT35R
  18. #43
    Oct 2016
    Philadelphia, PA
    E36 2JZ
    The car probably is pulling timing at those RPMS on a T3 manifold. What AR is the exhaust housing? You should be able to hit 650hp on that compressor. Also E85 uses more fuel Than pump gas which equates to more exhaust volume from the engine. A bigger turbine is normally better if you're not on pump gas. That's part of the reason why the torque hits so soon on E85. It's not all timing, otherwise race gas would have the same effect. (It doesnt)
  19. #44
    Dec 2011
    Glendale, CA
    01 M5, 99 M3 Turbo, Z3M
    What's up Dean. I just picked up Rod's Turbo M3. I see you guys are from the same area. I'll give you a follow in IG and hoping we can keep on touch on BFC.
    LOVING the car so far. Very cleanly built.
    [img]https://s1.postimg.org/2m3uctoxzz/IMG_2420.jpg[/img]
    1999 M3: RK Tunes, E85,
    GTX3582r: 585whp/608wtq @18psi
    2001 M5: Imola Red on Imola Red Interior, Evolve Alpha N Tune, IATS Relocation, AFE Dry Element Drop Ins, Dinan Front Strut Bar, Dinan Rear Swaybar, Dinan Springs and Koni Sports, Rogue SSK and Transmission Mounts
  20. #45
    Jun 2006
    San Jose, CA
    98 AW M3/2/5
    Quote Originally Posted by JOutterbridge View Post
    650whp? I believe it's a 0.82 housing on my GT35R.
    Quote Originally Posted by TechnoViolin View Post
    Nice! Yes, you got a good one...not many around anymore that clean with a well thought-out turbo setup.
    2006 CB M3/2/SMG
    1998 AW M3/2/GT35R
  21. #46
    Manchester, N.H.
    96 332IS 6466 turbo
    Eric (Litemup) made 800 on a t3 spa .81 AR with one of the best graphs I have ever seen.
    I believe mcoupemindy did the same. I don't think the housing is holding you back. Turbo is done. He happy with your accomplishments.
    1996 332IS
    Built 3.2
  22. #47
    Jun 2006
    San Jose, CA
    98 AW M3/2/5
    Definitely happy with the current setup, just planning for the future. I have a built motor on hand which i was planning to transfer over the same components to see what more boost (18-xx) would bring. If the GT35R has reached it's limit, i may opt for the next model up (same housing, same mani) as I don't want to redo the hotside work just yet.
    2006 CB M3/2/SMG
    1998 AW M3/2/GT35R
  23. #48
    Mar 2013
    Upstate NY
    M3
    Looks like my comment in the torque club was already noted. Nice car wish mine was clean like yours.
  24. #49
    Jun 2006
    San Jose, CA
    98 AW M3/2/5
    Quote Originally Posted by Mklock View Post
    Appreciate it, hopefully the built motor goes just as smooth.
    Looking for a Racelogic traction control now...anyone have one?
    2006 CB M3/2/SMG
    1998 AW M3/2/GT35R
  25. #50
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Quote Originally Posted by ///dean View Post
    Whats your tire setup?
  1. Body for E21 M60b30 Turbo Build and other goodies
    By 93FIM5 in forum 1988 - 1996 (E34)
    Last Post: 11-17-2011, 11:42 AM
  2. More Boosts! Tim's turbo E36 M3 build and fab thread!
    By A4RingedONE8T in forum Forced Induction
    Last Post: 08-04-2011, 08:30 PM
  3. Steinkek's Build and ?s Thread
    By Steinkek in forum 1975 - 1983 (E21)
    Last Post: 06-10-2011, 07:34 AM
  4. Replies: 50
    Last Post: 07-19-2009, 02:44 AM
  5. Sin City Turbo Build....Finally Dyno Sheet!!!!
    By GodFather in forum Forced Induction
    Last Post: 06-25-2007, 03:47 AM
