I have removed the drivers side ( LHS ) headlight assembly from the car and all head lights work. I now find that the yellow/ green power input is dead, and the RHS yellow blue is at 12V. I think this means the fuse is OK..it looked when I checked it. So it looks like the switch is faulty....tempted to run a like from the yellow blue over to the yellow green. Not at all interested in getting into the switch.Any comments!!??
Check out the link below to a tech article from our site. It should help you troubleshoot and fix your Xenon light issue. Best of luck!
http://www.pelicanparts.com/BMW/tech...eplacement.htm
-Dmitry
888.280.7799 | 6am - 5pm PST
Dimitry, Pelicans technical write up shows me how to do what i have already done. My driver's headlight unit works fine on the bench when powered by temporary wires to a 12V car battery! The yellow green wire is the power feed on the drivers side and it is dead, so i think there is a problem in the head lamp switch. To remove the switch is simple enough , but I have not seen anything indicating that it can be cleaned.I sense that there may be codings involved re the odometer, and I wonder if you can shed some light on that!? In the mean time I have installed a feed line from the yellow blue lamp power on the pass side over to the drivers side plug, and all lamps now work as required.This is most likely a temporary fix, until i get more info on the switch !?
