Results 1 to 5 of 5
Thread: Gasket flange oi leak need help bady.
    Dec 2015
    Philippines
    E87
    Oil leak, need help badly. Its driving me nuts and Im on the verge of selling
    Hey mates! So I've been hving trouble on my e87 because of oil leaks. I've been adding oil every 3000km because it rans out. Moving on I replaced my valve cover gasket, vacuum pump o ring oil filler cap and gasket flange. So I blocked all the leaks with new orings and equipments and went on for a while hving no trouble. After a few weeks the leak surfaced back on and it's coming out strong from the newly replaced gasket flange. Any thoughts why this keeps on hppening? I tightened the screws and put the gasket flange correctly but still it keeps on leaking. Thanks in advance part number of gasket flange is 11377502022. Im on the verge of seliing this car just because of this leak
    Dec 2013
    Chicagoland area
    EXOTICS
    What are the last 7 of your VIN# ?
    Dec 2015
    Philippines
    E87
    My vin number is jt43801. Its a 2005 n46engine 120i. The leak is coming underneath this gasket flange, check attached pics
    Dec 2013
    Chicagoland area
    EXOTICS
    High oil usage and cause of leaks is known to be result of defective crankcase vent valve. If hoses are brittle and cracked replace whole system:https://www.realoem.com/bmw/enUS/sho...diagId=11_3724 Replaced the oil separator on my e36/7 and massive oil leak problems from multiple locations disappeared. If your leak is only from gasket flange- check that no broken pieces from previous flange remain causing improper seal.
    Dec 2015
    Philippines
    E87
    Well oil leak is only coming from the gasket flange and in one of the screw thread of the cylinder head cover because of loose thread, is it still subject of defective crank case vent valve? I already checked for broken pieces and found non. Also, how do you repair a damaged thred from that part since it's the metal cylinder head itsef that hase the damaged thread? Should I drill it or what?
  1. Frustrating Tranny Leak, need help
    By KOM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-28-2008, 11:05 AM
  2. water leak need help
    By dz223 in forum 1991 - 1999 (E36)
    Last Post: 02-10-2007, 01:36 PM
  3. radiator leak! need help
    By amdspitfire in forum 1991 - 1999 (E36)
    Last Post: 09-09-2005, 11:56 PM
  4. Coolant Leak Need Help Searched
    By Simon Tibbett in forum 1991 - 1999 (E36)
    Last Post: 05-26-2005, 12:47 PM
  5. Put new HeadGasket now leaking?Need Help!!!
    By LUIS in forum 1992 - 1999 M3 (E36)
    Last Post: 08-04-2003, 03:09 PM
