Results 1 to 3 of 3
Thread: SMG to 6MT Swap- Drivability Issues, Loss of Power
    College Station, TX
    95 Mugello*rot m3
    Exclamation SMG to 6MT Swap- Drivability Issues, Loss of Power
    Hey there,
    recently had the swap done. Reprogramming was done with Autologic.
    There are no CELs, and the car drives great, except it really doesn't. The issue I'm having is fairly difficult to explain. In 1st gear, with the DSC off, from 4K RPMs, I can stomp on it and the rear tires wont so much as chirp. In fact, the engine doesn't even really start to breath until like 6k RPMs in 3rd gear.
    I was convinced that the VANOS ate shit, but after talking with Beisan it was pretty clear that wasn't the issue.
    After hooking up my Schwaben code reader I noticed it had an SMG related fault. "6 TIMEOUT SMG-CAN" or something like that. It was my understanding that Autologic was capable of completely erasing anything SMGII related. Is this correct? Is this fault code the reason my s54 feels about like an e30 318i until 4th gear or so?
    Somebody, please shed some light on why this car has lost its' sack.
    Nov 2015
    World
    '04 M3 and '06 MC ZCP
    I was looking into this too because I was thinking of getting an SMG and switching out with a 6MT. You didn't try reprogramming with the Autologic system? Also, I found this:
    Being3
    Wed, Feb-12-2014, 09:39:56 PM
    SMG to Manual trans DME modification
    change cfg_m.getriebetyp and cfg_s.getriebetyp from 40 to 03.
    In hex should be 0x8 and 0x4008
    Being3
    Wed, Feb-12-2014, 09:43:36 PM
    Also need to suppress SMG DTC codes
    0x06 (6) "Time out SMG-CAN"
    0x7B (123) "No CAN-bus signal from SMG"
    0xB1 (177) "MIL lights up due to prompt from SMG"
    Being3
    Wed, Feb-12-2014, 09:45:30 PM
    DiY DTC suppression thread
    http://www.m3forum.net/m3forum/showthread.php?t=458115
    Being3
    Being3
    Being3
    I think this might help. Let me know if it does.
    Here is the original link: http://www.m3forum.net/m3forum/archi.../t-467919.html
    Dec 2016
    Miami,Florida
    2003 bmw m3
    i had the same exact issue, turned out that you need to unplug the smg dme. that was my problem solver once i did my swap
  1. Tach reading issues...smg to manual swap
    By tynashracing in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 04-18-2008, 03:29 PM
  2. power steering issue...loss of fluid + noisy
    By DaveEye in forum 1988 - 1996 (E34)
    Last Post: 03-03-2008, 11:56 AM
  3. IPod to original head unit - no loss of CD autochanger
    By DReed in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-25-2008, 04:54 PM
  4. Loss of Power WOT 1st to 2nd
    By joeycuccaro in forum 1992 - 1999 M3 (E36)
    Last Post: 09-18-2007, 11:31 AM
  5. Loss of power, cats starting to smell, any ideas?
    By 95MMM in forum 1992 - 1999 M3 (E36)
    Last Post: 10-22-2003, 11:26 AM
