Results 1 to 13 of 13
Thread: Lubricating calipers
    Feb 2013
    Brisbane, Queensland, AUS
    '89 535i, '00 735i sport
    Hi all - I'mnow assembling my newly stripped and painted E38 rear calipers and a useful youtube diy video speaks of using a 'brake paste'. Is a normal antiseize product ok?
    John
    Carefree, AZ
    2000 528, 2015 X5
    Its one and the same though some A/S compounds are for higher temps, like braking applications. Check your label. I have used regular A/S with no problem but it doesn't last forever.
    Be sure to get it on the contact points where the shoes slide back and forth under braking. Don't get any on the rotor or pad. If you do, chase it with a shot of brake cleaner.
    Don't forget to "season" your pads after install. Light braking at first. Let them cool. The next day medium braking with a good cooling off period of driving. Then, on the third day, firmer braking followed by a cooling down period. Never slam on the brakes to the max, or brake hard and then park the car -unless its to avoid an accident! Heating new pads up to max temp right away can cause the friction material to separate from the metal backing. Slow heating-cooling cycles help prevent that.
    "Gute Fahrt!"
    Ray
    Jan 2016
    Ca
    2001 525it
    I use 3m silicone paste for the sliding parts
    Carefree, AZ
    2000 528, 2015 X5
    Silicone is high temp. No problems with it "running" during summer stop and go?
    I bought a set of Aussie "carbon composite" pads for my fronts on the 528. They were harder and supposedly lest dusty. In summer, they would start squealing and I'd take 'em off and clean them good, lube them and re-assemble. A month later, they started squealing again under light pressure. The anti-sieze was everywhere I had brushed it on EXCEPT between the slidey parts. Never could figure out where that was going. And that was hi-temp brake lube...
    Another one of life's mysteries....
    Ray
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    What about ceramic brake caliper grease?
    Jan 2016
    Ca
    2001 525it
    3m silicone stays in place
    Carefree, AZ
    2000 528, 2015 X5
    PB,
    That must be ultra-high temp stuff! Out here in Phoenix, in the summer, you need that kind of lubricant. My 528 had it easy at 0315 in the morning zipping down the freeway but the legs home at peak heat in traffic during rush hour were brutal. Fortunately I usually only made one round trip a week. The rest of the time the car sat.
    JC,
    Good to hear. Thanks.
    Ray
    Jan 2016
    Ca
    2001 525it
    3m part #08946
    Charleston, SC
    '15 I01Rex , '11F25
    I use Permatex ceramic paste, also be avised that contray to what people might say , the slide pins are brass, which is self-liubricating, no need for the grease.
    May 2016
    Lexington Park
    99 323Ci, 98328i verts
    Jun 2005
    New England
    Sil Glyde has been around for a while. I use to use it but have bedn using the Permatex Ceramic lately. I really dont know whether one is better than the other.
    May 2016
    Canada
    Are Slower than yours.
    Quote Originally Posted by ptarditi View Post
    +1
    +1 I use Silglyde for my DD and Permatex Ceramic ( purple stuff) for my Track rats.
    May 2016
    Lexington Park
    Yeah, just picked that tube up for the rebuild of the wifes "new" F100 brake system. New calipers and pistons. Freaking front calipers have more slide surface than an aicraft carrier elevator..... Caliper retention design is weird......
  1. Caliper Guide Pins lubrication??
    By CesarE1 in forum 2004-2010 (E60,E61)
    Last Post: 02-18-2014, 04:48 PM
  2. Replies: 6
    Last Post: 07-24-2013, 02:28 PM
  3. Hard Stop Led to Creaking Brake(s)? Caliper Bad? Lubrication Problem?
    By Landerholm in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-30-2013, 04:57 AM
  4. Brake caliper lubricant
    By curry in forum 1991 - 1999 (E36)
    Last Post: 08-24-2009, 08:12 PM
  5. I wanna paint my brake calipers...any tips?
    By xjeeper in forum 1992 - 1999 M3 (E36)
    Last Post: 03-20-2001, 08:26 AM
