I have good transmissions to swap into my 01 740 Sport (220k miles) and 01 750 (125k miles), and will be swapping them both in soon.
Wanted to get opinions on what else to replace while the transmission is out.
1. Coolant block plate gasket and rear main seal - these are a pain (at least the rear main seal with the special tools involved) and I very rarely hear of them ever leaking - are either or both of them worth replacing? I always worry about new work possibly causing new leaks (if it ain't broke...)
2. Opinions wanted - I have a 3.15 LSD for the 750, have been debating whether to do it at the same time as the transmission to save some work, or wait for later to isolate any issues from each one.
3. I have Guibo, CSB, and every other driveshaft part and new hardware ready for the 750 - if I only do the transmission now, which of these should I replace now vs. wait for when I do the diff? I was thinking just Guibo.
4. On the 740, the new transmission is not tested, but supposedly OK with 147k miles. There is a warranty on it, but I doubt it would cover labor. The old transmission ran perfectly except for F drum failure (no reverse). Should I swap in the known good torque converter, although it potentially has 220k miles?
5. Any other suggestions on anything to replace?
not really a while it's out, but back in... replace oil + filter. I'm more of a replace it while you're already in there guy but can understand the "if it ain't broke" mentality as I do the same from time to time. I've only owned my e38 for 3 years now and have yet to read someone replacing the rear main + gasket so in this scenario, I would say leave it BUT, if you see any coolant residue or oil residue, replace.
The harness o-rings f0r sure.
And make absolutely sure the filter is in real tight, try to pull it off if you can without much effort then get a better o-ring.
The World is ruled by Kings and Queens that blind your eyes and steal your dreams.
When answering my questions please use a qualifier if you are not sure.
The more I work on this car the less I respect German engineering.
When you speak in Absolutes you are always wrong!
Semper Fi
