Results 1 to 4 of 4
Thread: Can less oil lead to faster oil loss?
    Sep 2015
    San Mateo, California
    1998 BMW M3 Sedan
    Hey all, I was just wondering if my car being low on oil could be a contributing factor to my oil loss. someone correct me if I'm wrong, but having less oil would mean it would heat up faster, and typically when you have less of any fluid it burns faster? So i was at about half my tank of oil, would it make sense that my car is using slightly more than it would normally with a full tank?
    Aug 2016
    Usa
    2008 328xi
    If it's within safety limits then no it will only get dirty faster...same contaminants going into less oil. Now if your oil is low enough to where your not oiling your motor correctly and its temp go's above normal then yes you will use more.
    If your motor has a lot of age and you are burning oil it is safe to say thicken your oil...it will be harder for thicker oil to get past worn rings and seals...jest stay within factory recommendations...example if your using 5w30 you can go 10w30...the increased tolerance in the bearings from age would allow the thicker oil.
    Sent from my LG-H901 using Tapatalk
    Trumbull CT
    1998 M3 Vert, 1992 318i
    Quote Originally Posted by tooshfty View Post
    No, that's not how it works. Yes it will warm slightly faster, but not enough to make any difference. The only way it goes away faster is by percentage, but not absolute volume/time. As saii said though, if you were actually overheating to scorching temps then maybe...
    Quote Originally Posted by Saii View Post
    10w30 isn't thicker than 5w30 at operational temperature and thus will make no difference. Switching to a 5w40 or even a 0w40 is thicker at operating temps.
    OP- you need to figure out where the oil is going and fix that. Valve cover gasket, PCV, front and rear mainseals, and valve seals are all possible points of loss.
    Caprica Junkie
    Quote Originally Posted by boarder2k7 View Post
    Correct, the w actually stands for "winter" denoting that the first number is the viscosity when cold. This information is not as widespread as it probably should be....
    PRICE CUT on ALL FABRICS
  1. Turbo oil drain to stock oil pan drain bolt
    By BMWManiac in forum Forced Induction
    Last Post: 08-28-2014, 10:00 PM
  2. Turbo oil drain to stock oil pan drain bolt
    Last Post: 08-06-2011, 10:10 AM
  3. Modify oil pump to incresae oil pressure?
    By M52 POWER! in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-05-2008, 09:43 PM
  4. What can cause 1989 325is to leak oil big time?
    By DaveE30 in forum 1983 - 1991 (E30)
    Last Post: 10-16-2007, 08:37 PM
  5. Anyone notice that K&N leads to increased oil use?
    By dmw in forum 1992 - 1999 M3 (E36)
    Last Post: 02-28-2005, 11:08 PM
