not counting much on replies in this forum but i need all the information i can get, my car 320i m52 1995 car is running rich, i have 2 temperatures sensorsi have error code that i am not fully understand what it is, 202 fuel trim limit bank 1.
11781734670, if temperature sensors do no effect fuel/air ratio what does?
if anyone have any idea please reply!
Never FAST ENOUGH
Thanks for replying, I do not have oxygen sensors, pre cat only temperature sensors, that is my dilemma
No vacuum leaks, idle is perfect, but when pushing it on sport mode I even smell the gas
Obviously it's lambda or o2 sensors related but I do not have them, in oem manual they described as temperature sensors or lambda zonde, I bought brand new sensor 11781427884, but his plug just does not fit, and seal color of mine are yellow and new one is green.
Never FAST ENOUGH
Yes, just viewing that on realoem.com Have you checked and cleaned the MAF? Enter last 7 of VIN on realoem for actual part# needed for temp sensors.
well i will maintain maf, and i did enter my vin in realoem those are part number 11781734670 for temp sensors, thank you
what is the right compound for cleaning the maf?
Never FAST ENOUGH
If available CRC MAF sensor cleaner
not sure if i will find it where i live, thank you for your help i will update on progress
Never FAST ENOUGH
