I just purchased a 2011 BMW 328I and I noticed it has run flat tires and that the front tires and the back tires are two different sizes. So someone told me that on a run flat tire you can drive 50 miles up to 50mph to get it repaired and etc. Is that true? I'm not sure how they work. Also when the tires are rotated stating that the front and rear aren't the same size...in what way would they be rotated?
You can't rotate your tires, since your car is in a staggered setup. Smaller size in the front and wider tires in the back.
