Hi my problem with ncs is when i try put my e39 vin number to Fa it says vin is faulty
And also when i try to Rear zcs or whatever from like ike or kombi or ews it opens New Windows which says that coapi error 2000
I have changed almost every file and daten and etc on ncs but still not working
What could be Wrong with it?
Thank you
What version of NCS and which interface are you using?
Ncs 4. 0.1 if i remember correcly and using inpa cable (works with inpa btw) and also i have galletto cable
NCS 4.0.1 uses EDIABAS v7.*.* which is probably too new for your E39 - try using NCS v3.1.0 with EDIABAS v6.4.7. Also make sure your DATEN files are up to date.
Where i can get that edibas 6.4.7?
I found ncs expert 3 and I can update that but
How can i update edibas to that 6.4.7
And what about inpa? Do i have to make any modifications on there?
Check which version of EDIABAS you have installed currently - the version information can be found in the first few lines of EDIABAS/Bin/Ediabas.ini (open with Notepad). EDIABAS v6.4.7 was standard with INPA v5.0 and v5.02. If you want to install v6.4.7, rename your current c:\EDIABAS file (EDIABAS7 or EDIABAT?), then install only the EDIABAS component of INPA, which will install to c:\EDIABAS by default.
now i get coapi 1000 and 1100 ecu not covered by detection ike error after i choose IKE ecu to read,
what could be wrong with this?
Untitled.jpg After long uninstalling and installing i dont get anymore errors from vin or anything but just when i try to load zcs from ecu (any ecu ike, komb, ews) it gives me this error message?
do anybody have any help or answers please?
i have to get my abs module coded before friday
Untitledjlljj.pngand here is sc from this error log
Have you previously added functions to your vehicle order or has the car been converted from automatic to manual transmission?
No it is automatic there have been installed euro 2 update with SAP and post cat Lambda delete but nothing Else i think
Could that euro 2 update be a problem?
What that fault code in ncs means?
It means that the vehicle order is not consistent with the options fitted to the car.
Is there something i can do for it?
If the SAP you are referring to works in conjunction with your nav system, I think that it may be causing the car to think the nav system is not the same as the one specified in your vehicle order.
Nooo secondary airpump and this module does not have any nav so i dont think they can do any harm?
I mean this car havent got any nav (type error)
Use INPA to read and clear errors in your EWS, KOMBI and IKE. From reading the error files, it appears that there may be a problem with your instrument cluster coding.
Here is a list of CoAPI error definitions, courtesy of a Russian forum:-
; COAPIERR.TXT
[VERSION]
VERSION = 3.6.0
[COAPIFEHLER]
; 1000..1019: Common error
1000 = Error
1001 = Invalid action
1002 = Not enough memory
1003 = Invalid parameter
1004 = The buffer is too small
1005 = COAPI text data file errors "coapierr.txt" not found
1006 = COAPI text array% s error data does not release
1007 = COAPI text array data error% s is version% s, COAPI same version is% s
; 1020..1039: An array of data errors
1020 = The data set can not be read
1021 = The data set can not be written
1022 = Error reading data file
1023 = Error writing to the data array
1024 = parameter performance (coapi-Function wrong)
1025 = The configuration data not found
; 1040..1059: array Data processing error (syntax error)
1040 = An error in the processing of bulk data (total)
1041 = Error in ZST-array processing of data
1042 = Failure in CVT-array processing of data
1043 = Error in the CBD-array processing of data
1044 = Error in SGET-array processing of data
1045 = Error in SWT-array processing of data
1046 = Error in ZCSUT-array processing of data
1047 = Error in VM-Programming
; 1060..1079: CABD-DateiVerarbeitungsFehler processing an array of data (syntax error)
1060 = An error in coding / execution descriptor data
1061 = CABI has not been initialized
1062 = CABD-error results (CABD-Ergebnisparameter)
1063 = CABD-error setting parameter (CABD-Auftragsparameter)
1064 = Internal error CABD-Job
CodierVypolneniya(Execution)S 1065 =% s is not found or an erroneous
; 1080..1099: Codierschluessel- and Fahrgestellnummernfehler
1080 = Codierschluessel incorrect
1081 = GM-Schluessel incorrect
1082 = SA-Schluessel incorrect
1083 = VN-Schluessel incorrect
1084 = AM-Schluessel incorrect
1085 = FGNR wrong
1086 = Identification number of jobs is not true
; 1100..1119
1100 = Basic data on SG-definition does not contain
; 1120..1139
1120 = Found unused data encoding (Codierdaten)
; 1140..1159: Schluesselwortfehler
1140 = ASW mistake
1141 = FSW mistake
1142 = PSW mistake
1143 = SG-short for wrongly
; 1160..1160: Customization
1160 = Found Customization-FSWs
; 1170..1179: SGVT-Fehler
1170 = SG disabled (disabled)
1171 = Error in SGVT-Performs the total
; 1180..1189: AT-Fehler
1180 = The task for a / m wrong
1181 = Error in AT-general Execution
; 1190..1199 BSU-Fehler
1190 = Bootsektorupdate not possible (ggf. but also do not make)
1191 = Bootsektor ECU already suitable for HW * -Soll and SgFam-Soll
; 2000..2019: EDIABAS and SGBD-Aufruf- / Ergebnisfehler
2000 = Error in EDIABAS or in the array of data Auto-Descriptions
2001 = EDIABAS not initialized.
2002 = Unexpected EDIABAS-result.
2003 = EDIABAS-parameter error (SGBD-Parameter)
2004 = EDIABAS-parameter error, a binary buffer.
2005 = Internal error in SGBD-Job
; 2020..2039: EBUOshibki communication
2020 = VEHICLE NOT responding.
2021 = Data transmission to SG broken.
2022 = The battery voltage is too low or absent.
2023 = Wrong response message.
2024 = Error Baudraten not legible
2025 = Error Take away the car in memory.
; 2040..2059: Computer Error detection
2040 = False identification (general)
2041 = False coding index
2042 = False hardware number (HW)
2043 = The fake program number (SW)
; 2060..2079: Codierfehler
2060 = Encoding mistake (General)
2061 = Failed to encode data in records
2062 = Failed to read data coding
2063 = Failed to encode the comparison / verification
2064 = An error in the coding-reading (navmer ZCS)
2065 = checksum error
; 2080..2099: Programmierfehler within E65 (TI435, Mr. Drexel)
2080 = programming status is wrong
2081 = Authentisierungfehlerhaft
2082 = Flash erase error.
2083 = Flash Download incorrectly prepared
2084 = Flash Recording wrong.
2085 = Flash load closing incorrect
2086 = Signaturpruefung incorrect
2087 = AIF incorrectly read
2088 = AIF incorrectly write
2089 = programming mode is wrong switch
2090 = Authentisierung dimensional errors
2099 = Prozessortyp incorrect
// 3000..3050: COAPIKF internal error
3000 = The number of the mount in the "xxkfconf.da2" found ZB-Dateien
3001 = Error coding in Flash erasing
3002 = Error in Flash erasing
3003 = Failed U-Batt in Flash erasing
3004 = Error in comparison ISN DME and EWS
3005 = Error reading ISN
3006 = Error, different starting values
3007 = Error, unknown EWS-interface
3008 = Error switch.
3009 = PS10 InitString found
3010 = VERSIONKFCONF not Zusbau
3011 = Referenz Auto Kennung
3012 = Referenz project
3013 = Referenz program
3014 = Referenz draft version of the new SGs
3015 = Referenz not existing file (navmer GD834)
3016 = API32.DLL could not be loaded
3017 = coapiKfInit () fehlgeschlagen
3018 = apiInit () fehlgeschlagen
3019 = Referenz not of Auto auslesbar (EMS2000)
3020 = Steuergeraet not PrgIfSel dataset found (not necessarily always a mistake)
3021 = Total EWS-Error
3022 = The required basic Parametr not compromised.
3023 = PABD not contain a valid action in the main diagn. address.
3024 = KFCONF found.
3025 = SgMember found
3026 = end of file
3027 = Information - data not found
; 4000..4199: error code DAT- module (Grasping at Ken Logistikdaten field programming)
4000 = Note: This parameter was NULL-Zeiger
4001 = Invalid parameter
4002 = File not found.
4003 = Error in Schreibdatei oeffnen
4004 = Error reading file
4005 = Error in writing file
4100 = Error in dlo- respectively rec-Modulen
4101 = Error in ASCII-> Hex-conversion
4102 = The required number of% s to% s dataset found
4103 = Error in symbolic PlatzHaltern
4104 = Report function call parameter
4105 = no Eintraege more in NWNR.DME / AGS / DAT available
; 4200..4300: error code ATB- module
4202 = Dimensional syntax error
4203 = berlauf
4204 = File% s not found
4205 =% s file was not opened for writing
4206 =% s to read the file error,% s String
4207 = Error writing file
4208 = Wrong Way
this line 4209 =% s Pruefsumme fuer incorrectly:% s
4211 = The string syntax error in the Convert File
4212 = Uncertain Character
4213 = Conversion Error
4214 = False conversion name
4215 = Allokierungsfehler
4216 = To many Records
4217 = Invalid name - Check
4218 = Syntax error in Definition-File
4219 = Uncertain key to the cipher
4220 = Unexpected end of block (ggf. missing $ REFERENZ)
4221 = data array conversion error% s,% s String
4222 = Do not let the deposit corresponds decks $ BLOCKANZAHL
4223 = The last line of alignment EOF-Record
4224 = Convert an offer data set is not
AIF has
4225 = Konvertirovannoy dataset may not sodezhit AIF
; 4300..4400: error code module REC-
4301 = End of file
4302 = File not found
4303 = File could not be open for entries
4304 = Error reading file
4305 = Error writing file
4306 = checksum error
4307 = Uncertain Parameters
4308 = Invalid parameter
4309 = To many data-bytes Record
4320 = Error Versions
4321 = REC-ID error
4322 = WRITE-format ID is not correct, or a short
4323 = Record-unknown device (not B (yte) or W (ord) usw.)
4324 = Speicherberlauf
4325 = To many entry-IDs
; 4400..4600: error code NCK-Modul (Codierung)
4430 = Urgent action error
4431 = The key is not activated to the code
4432 = File not found
4433 = File not opened for writing
4434 = Error reading file
4435 = Error writing file
4436 = error string types
4437 = Invalid Operator
4438 = The key to the code is invalid
4439 = The key function to the code is invalid
4440 = Paramaterschlsselwort invalid
4441 = Syntax error in carrying out the conversion
4442 = Data length - is wrong
4443 = Allokierungsfehler
4444 = To many entries
4445 = Compare coding index - error
4446 = The file names are not similar
4447 = Error in recording analysis
4448 = An error in the formula analysis
4449 = COAPI_NCK_ANALYSE_AAD_ERR, rolling the expression is not true
4450 = Write-ID is wrong
4451 = Error reading ZCS
4452 = Failed in saving to the cipher key pair (Listenberlauf)
4453 = Error reading FSW / PSW
4454 = The key comparison is not true
4455 = Write - can not be found
4456 = Error in records - Reading
4457 = Error in terms of rolling (AAD emptied, ASW is not put, ungueltiges sign in Formelstring)
4458 = job number is invalid
4459 = CVT incorrectly (Rolling expression does not have any true expression)
4460 = Syntax error in the Definition file
4461 = Uncertain key to the cipher
4462 = Uncertain SCHLSSEL-ID
4463 = length of the string - error
4464 = ZCS length incorrect
4465 = Decoding invalid characters
4466 = Coding value is invalid
4467 = No data to record
4468 = Error writing (non-specific error)
4469 = Error Reyvelichina
4470 = Error reading key to the cipher with profile
4471 = Incorrect data Name Records
= 4472 based on the coding, the information is incorrect Exemption
4473 = base encoding, a key to the cipher illiterate
4474 = Installing, Removing Infomatsiya incorrect
4475 = Installation of the key to the code is incorrect
4476 = Change Recovery Infomatsiya error haft
4477 = Change the key to the cipher illiterate
4478 = Addition, Extraction Infomatsiya incorrect
4479 = Supplement, the key to the code is incorrect
4480 = Number of pieces Extract Infomatsiya incorrect
4481 = The number of the key to the code is incorrect
4482 = History, Recovery Infomatsiya incorrect
4483 = The history, the key to the code is incorrect
4484 = checksum error
4485 = The file name is wrong
4486 = coding index illiterate
4487 = HW-room illiterate
4488 = SW-room illiterate
4489 = Organization of the battery is incorrect
4490 = Anlieferzustand incorrect
4491 = Data Coding group is wrong
4492 = manufacturer's data incorrect Group
4493 = Group data incorrectly restrained
4494 = erroneous data Unbelegt1-group
4495 = erroneous data Unbelegt2-Greppi
4496 = faulty parameter ZUWEISUNGS-FSW
4497 = faulty parameter Zuweisungs-PSW1
4498 = faulty parameter Zuweisungs-PSW2 (line implications to PSW1)
4499 = erroneous direct parameter Zuweisungs
4500 = Error in Kennung KK
4501 = Error in Kennung D
4502 = Error in Kennung X
4503 = Error in Kennungen
4504 = Error mask
4505 = Expensive incorrect
4506 = more than an expression of the true Rolling available
4507 = ZUT-ID found
4508 = Group is invalid
4509 = erroneous Umschlselung (Umrstzeile for the BR is not available)
4510 = erroneous Umschlselung (Umrstzeile for the car is not available)
4511 = Internal error (ASW Ray macaw)
4512 = rolling error
4513 = COAPI_NCK_SG_ID_INFO_ERR, internal error (Auto Ray macaw)
4514 = Invalid Bands
4515 = Error string
4516 = Compare the date read error
4517 = Mistakes
4518 = erroneous Bestellzeile
4519 = Error Date
4520 = The boundary data errors
4521 = read checksum error
[DEBUG]
VON = 9000
BIS = 9999
TEXT = Debug
Also i noticed that the same errors as in pictures comes when i try to Rear ecu even without any obd cable connected so i dont think that there is any problem with the car
Have you attempted to run a diagnostic using INPA? There are at least 6 different "INPA" cables - if you are using a K+DCAN interface, you will need to have pins 7 & 8 on the OBD end of the cable bridged. If your E39 has the round 20 pin diagnostic port under the hood/bonnet, you should be connecting to that using a 20 pin to 16 pin adapter cable.
Yep i have this k-dcan cable and pin 7 and 8 have been soldered, inpa 5.0.2 is working fine and I can read any module which i tried.
E39 is 12/2000 so there is no round connector under hood
Is there anything anymore which i could try to do?
can anybody please give me full working ncs expert with working e39 daten files, edibas etc please?
or if somebody knows whats wrong with this build please let me know....
getting kind of bored for this software not working-_-
Untitled.png-_-
Or if even somebody has got a working edibas and ncs files if you could email me juhnukka95@gmail.com i would be More than thankful i have to get this to work by the evening
If someone is having same problem and losing their minds for this so here is a answer for your problems
http://www.bimmerfest.com/forums/sho...d.php?t=879366
Worked for me perfect
