Page 1 of 5 12345 LastLast
Results 1 to 25 of 108
Thread: CES Motorsport BW 8374 EFR vs GTX35R Testing and GA 1/2 Mile event
    Mar 2003
    NC
    CES Stage 3 Turbo M3
    Getting prepped and ready for the 1/2 mile event in GA this weekend ... Euro Evo Getrag 6 speed trans installed, DSS 6 spd carbon shaft installed, BW 8374 EFR turbo installed, DKnight custom underpanels installed.... Should be interesting
    For this event, we decided to bolt up the Borg Warner 8374 EFR turbo to our shop E36 M3 with the updated Steedspeed TwinScroll E36 manifold that is finally ready for production, to see just how well this turbo stacks up to the Garrett GTX35R. Since we have tons of dyno data with the GTX, and the 8374 is a very similar turbo, we thought it would be a great comparison. We installed Borg Warner's 1.05 a/r External WG housing on the 8374, along with the Turbosmart Hypergate 45 wastegate, and put the car on the dyno for some test runs...
    The first graph is the comparison dyno of the Borg Warner 8374 EFR turbo running their 1.05 a/r ewg T4 twinscroll housing, versus our previous best run with the Garrett GTX35R 1.06 a/r T4 twinscroll housing... Same Nick G tune with draw thru 803 MAF OBD1, MS109 Fuel, 26 psi.... Ambient Air Temps were within 5 degrees between these two runs, with the GTX run at 75 degrees and the EFR run at 80 degrees.
    We saw a net gain of +40whp and +55wtq at 3800 rpm with the EFR turbo...
    and.... 423wtq and 16.7psi at 3000 rpm... Is this a record for a single turbo of this size at this rpm? Flow was slightly better up top with the EFR vs the GTX, but spool was significantly better.
    We will post more updates after this weekend on how well this setup performed. Our previous best at this event was 168.5 mph... Looking to beat that this time around.
    The CES Motorsport Team
    Manchester, N.H.
    96 332IS 6466 turbo
    180 mph.
    Don't get stopped at those speeds.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Austin, TX
    S13, Turbo M3
    Great testing as usual! This really shows the 8374 shine down low and in the mid range. EFR FTW!
    Mike
    IG: @mikevanshellenbeck
    NY/FL
    '99 Acura CL, '98 M3/4/5
    Is the EFR internally or externally gated?
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
    Manchester, N.H.
    96 332IS 6466 turbo
    Will this EFR be the new turbo for the famous CES "GTX " car ?
    1996 332IS
    Built 3.2
    May 2003
    quebec
    |99 Turbo M3 | 2K7 335|
    Nice! What injectors/fuel pump?
    Envoyé de mon SM-G920W8 en utilisant Tapatalk
    _____________________________
    May 2012
    Saskatoon, SK, Canada
    1994 525i touring
    I've been awaiting data on the efr turbos, this is great! Can anyone comment how the efr run starting a few hundred rpm earlier would affect the low end/mid range in this scenario? Seems to me it's giving the efr the advantage. Regardless, looks like a fantastic turbo for this motor.
    Sent from my A0001 using Tapatalk
    Louisville, KY
    turbo m3
    Who would think that there could be something better than a gtx at spool up.
    I wonder where the compressor taps out.
    This is my signature....
    Jun 2005
    Concord, NH
    08 E90M3; 99 E36M3 Turbo
    Quote Originally Posted by BadBoostedBmwM3 View Post
    786 rwhp on Sound Performance's dyno (not sure of brand and some say it reads high) on a fully worked Supra.
    Ellay, CA
    BMW Z3 3.0 VF SC'd
    SWEET BABY JEEZUS!!!
    Welp...that's just thrown a wrench into my build budget! How much more does an externally-gated EFR 8374 with TS housing cost than a GTX358R?
    "You don't win silver....you lose gold."
    Mar 2008
    Tempe, Az
    03 M3,Turbo E36 M3, D675
    Quote Originally Posted by danomite View Post
    Probably less
    Ellay, CA
    BMW Z3 3.0 VF SC'd
    Quote Originally Posted by MTrace View Post
    Probably less
    I'm starting to believe the BW hype...that is scary strong, and scary fast! Soooooo much spoolage!!!
    May 2003
    Richmond, Virginia
    Lots.
    It's a Mustang Dyno, but reads significantly higher than a dynojet. That 786 is likely much closer to 700rwhp.
    915whp '98 M3 Sedan /// 37k Mile '95 M3
    Dec 2004
    Milford,CT
    95 M3
    I have a sudden urge to order some aluminum sheets
    95 M3, 5.3 LS, PTE 7675CEA, TH400/Gear Vendors OD
    10.4@136 Pump gas at 3530lbs.
    Build thread
    http://www.bimmerforums.com/forum/sh...LS-Turbo-build
    Toronto, Canada
    E36 Turbo
    That's an impressive powerband!
    E36 · DYNO · TUNING · WIRING · PARTS
    Vancouver, BC Ca
    1993 325is
    Very interested in how the driveshaft works out. What attachment is at the diff end? 6 bolt CV style or 4 bolt universal joint? Also, any chance you got a weight before bolting it in?
    Vancouver, B.C., Canada
    '97 M3
    The carbon fiber one weighs about the same as the stock driveshaft. The Chromo one is heavier.
    Sent from my GTX3582R
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by chikinhed View Post
    I certainly hope not. That makes no sense! Not doubting you Brad, just wondering why the hell it's THAT heavy!
    Joliet, IL
    Out of Service
    Quote Originally Posted by jakermac View Post
    Torque. Need a lot of CF to handle the torque. Adds weight, plus the joints of course
    Sent from my SM-G935V using Tapatalk
    Vancouver, BC Ca
    1993 325is
    I hear ya! I'm still interested in knowing what joint is at the diff. Is there some sort of plunge joint like an American Iron driveshaft has at the transmission? I wanna do a lightweight driveshaft for my car, but only if I'm dropping a significant amount of weight from the 17lb OEM driveshaft that's in the car now. I'm not YET worried about mega power/torque. I'd also be very interested to know if there are any interesting harmonics in that driveshaft seeing as how it'll probably be seeing 150+ mph for a LONG time. The 84" carbon driveshaft I had in a custom build Honda started to get kind of "shaky" at 130-140mph on the dyno.
    Joliet, IL
    Out of Service
    I hear ya! I'm still interested in know what joint is at the diff. Is there some sort of plunge joitn like an American Iron driveshaft has at the transmission? I wanna do a lightweight driveshaft for my car, but only if I'm dropping a significant amount of weight from the 17lb OEM driveshaft that's in the car now. I'm not YET worried about mega power/torque. I'd also be very interested to know if there are any interesting harmonics in that driveshaft seeing as how it'll probably be seeing 150+ mph for a LONG time. The 84" carbon driveshaft I had in a custom build Honda started to get kind of "shaky" at 130-140mph on the dyno.
    Straight from their website. Regarding the CF E36 shaft
    This is our 1-piece conversion for the BMW E36 platform. The shaft is made from 2.75" x .170" tube with a 108mm CV to mount to the differential, which will eliminate any possible pinion angle issues. This shaft weighs 20lbs and since we are removing the hanger bearing, it will make the car seem more athletic and give it a smoother power transfer. This shaft is now being balanced on our new 9500RPM balancer to ensure a perfectly balanced shaft. Comes complete with adapter plates to mount up to the transmission and differential flanges and all necessary hardware for installation.
    PART# BMWSH2-CV-S
    Please Note: The E36 M3 uses either a 4-bolt or 6-bolt rear differential flange. This driveshaft is for the 6-bolt rear differential ONLY. If you're vehicle has a 4-bolt rear flange, please see part# BMWSH1-CV-C. Please verify which differential flange your vehicle has before ordering.
    Part Number: BMWSH2-CV-C
    Vancouver, BC Ca
    1993 325is
    Thank you. I have read that before.
    '97 M3
    Carbon fiber dampens vibration better than the steel does. I'd like the carbon fiber DS but it's ricey. ..... I mean pricey
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    How bad does the chromoly vibrate on the street?
    Jun 2005
    Concord, NH
    Quote Originally Posted by E36 HateR View Post
    In my opinion, a lot. Makes the car a lot less enjoyable. At about 3500 rpm my car sings and I want earplugs.
  1. Coupe vs. sedan comfort and gas mileage
    By bngl3rt in forum 1992 - 1999 M3 (E36)
    Last Post: 11-04-2014, 10:02 PM
  2. Replies: 137
    Last Post: 04-14-2014, 11:23 AM
  3. CES GTX35R test and tune
    By SM3 in forum Drag Racing
    Last Post: 11-14-2012, 01:05 AM
  4. Replies: 13
    Last Post: 11-27-2010, 01:29 PM
  5. Ran compression test and clt after 110k miles
    By Driggers14 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-17-2006, 05:58 AM
