Results 1 to 1 of 1
Thread: 1995 540i Driveshaft Disassembly Problems
    Sep 2015
    Bay Area, Califorbia, U.S
    1995 BMW 540i
    Hello, I am replacing my Central Support Bearing, I took off my guibo joint, marked the drive shaft where it comes apart, and am now trying to get to the clamping sleeve and the bolt on the inside of the U joint.
    The U-Joint bolt turned out to be smaller than 19 but bigger than 17 (Seriously Germans?) Can I take the clamping sleeve without taking out the bolt first?
    I have been looking at the repair manual, but the images show the clamping sleeve much more visibly (smaller size diff) than mine and am not sure which component here is the sleeve.
    http://imgur.com/d2g4f0S
    Is it the thin section of drive shaft past the worn out bearing, and will pliers do the job?
  1. 1995 540i/6 driveshaft problems???
    By sutton540 in forum 1988 - 1996 (E34)
    Last Post: 07-01-2013, 10:28 PM
  2. 1995 540i ignition lock problems
    By VenomRS4 in forum 1988 - 1996 (E34)
    Last Post: 05-09-2011, 01:16 AM
  3. 1995 540i electrical problem
    By Jfan16 in forum 1988 - 1996 (E34)
    Last Post: 01-04-2010, 07:56 PM
  4. 1995 540i Firing Problems
    By bobbyt in forum 1988 - 1996 (E34)
    Last Post: 02-04-2009, 01:39 PM
  5. Help Needed on 1995 540i e34 Fuel Problem
    By UpstateBeemer in forum 1988 - 1996 (E34)
    Last Post: 09-10-2006, 05:11 AM
