Page 1 of 5 12345 LastLast
Results 1 to 25 of 124
Thread: FS: 99 M roady part out Silver over Black
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    Prices are OBO +shipping +3%paypal fee. Unless otherwise stated.
    Cash is king, that said you are welcome to put non-refundable deposits on items you know want that we can negotiate how much and for how long. I will communicate with everyone as quickly as I can but first to put money down is the first to get the part.
    I will not hold dibs or items without a deposit.
    THE SHELL IS GONE, ALL I HAVE IS WHAT IS LISTED.
    I will ship what I can, and can maybe arrange freight if needed, but larger items I may request you arrange your freight details.
    VIN: LC88819
    Milage: 120750 ish
    ALL PRICES are OBO
    The known bads:
    Front bumper
    Pass front rim
    Driver glass
    Setrab oil cooler
    Core support
    Frame rails
    Side skirts
    Driver strut
    Shifter surround plastic panel
    No clock
    The goods:
    Engine:
    SCRAPED Z3M driver engine mount arm with PS res and bracket
    SOLD Full Exhaust including:
    · S52/M52 Racelands
    · 2x 2.5" Vbands front
    · Catless dual 2.5" midpipe with resonators and H-pipe
    · 2x 2.5" Vbands rear
    · 2x Vibrant dual tip mufflers (1040's maybe?)
    SOLD S52 Z3M wiring harness, missing end of MAF wiring due to SC harness
    SOLD VF supercharger V3 kit including:
    · Nick G tune (running 6psi currently, tune good to 8psi)
    · VF injectors
    · spark plugs
    · boost gauge
    SOLD S52 long block w/ stock internals, including
    · New valve cover gasket at 108K miles
    · Coil packs at 108k
    · New oem cam/crank sensors at 108K miles
    · Bimmerworld low temp Tstat
    · Metal impeller water pump w/ new o-ring
    · Brand new Oil filter housing to block gasket
    · Includes PS pump and AC compressor
    · No ECU/harness/manifolds
    Drivetrain:
    $250 Z3M rear axles
    SOLD 3.73 Diff w/ dual ear cover
    SOLD MZ3 shifter lever
    SOLD M rear end, including:
    · IE subframe bushings
    · Subframe
    · Rear trailing arms
    · New rear trailing arm bushings (oem) at 104k
    SOLD trans mounts (SHIPPED)
    SOLD ZF trans, including:
    · New OEM clutch replaced at 104K miles
    · New OEM dual mass flywheel at 104K miles
    · shift pin service
    · braided steel clutch line & slave
    Suspension:
    SOLD Front strut reinforcement plates (pair)
    SOLD Z3M tophats
    SOLD Koni yellow front inserts
    SOLD Koni yellow rear shocks with Rogue RSMs
    SOLD Z3M steering rack
    SOLD H&R street springs
    Wheels/Tires:
    $20 Chrome "Security" lug bolts
    $(Make offer) OEM lug bolts
    SOLD Rear roadstars
    SOLD Front single roadstar
    SOLD Set of Bridgestone TE760 (225/45 245/40)
    Exterior:
    SCRAPED Mroady trunk PRICE DROPPED 7/27
    SCRAPED Driver rear fender, slight damage (NO ANTENNA HOLE, which is weird but is OEM, no previous hole filled) PRICE DROPPED 7/27
    SCRAPED Set of metal heat shields (trans tunnel minor damage, missing one fastener from driver rear shield) PRICE DROPPED 7/27
    SCRAPED Hood (Nose dented, wind knocked it over on my trailer and has two dents in top) PRICE DROPPED 7/27
    SCRAPED pass front "fender" PRICE DROPPED 7/27
    SCRAPED gutted driver door skin (no handle, window parts, or latch) PRICE DROPPED 7/27
    SCRAPED Clean washer tank cap SHIPPED
    SCRAPED Lower door weather strips Ea ($55 pair) (I just bought a new one for $45+shipping a month or so ago!)
    SCRAPED Heated washer nozzles (pair) SHIPPED
    SOLD driver front "fender"
    SOLD M gills
    SOLD
    Soft top assembly
    SOLD Hardtop with hardware
    SOLD M mirrors
    SOLD eBay headlights
    SOLD driver taillight
    SOLD 3rd brake light
    SOLD Passenger sliding glass
    SOLD Passenger door skin
    SOLD Fender lights
    SOLD Trunk seal
    Brakes:
    $375 Complete M front brakes with knuckles, pads, calipers, SS lines, mounts & discs
    $275 Complete M rear brakes with pads, calipers, SS lines, mounts & discs
    $75 Z3M master cylinder & booster PRICE DROPPED 7/27
    Interior:
    $27 Glovebox anti-sag fix "kit" (SHIPPED)
    $75 -99 hardtop defroster connectors w/ pigtials (chassis side only!) for pre-power top owners that want to have a function hardtop
    SOLD -99 rear defroster switch
    SOLD HK amp
    SOLD NRG short hub adapter
    SOLD
    Column switches
    SOLD Passenger airbag cover
    SOLD Roady fitted box with Alpine 10" SWR sub
    SOLD Roll hoops w/hardware & trim
    SOLD Autodim mirror
    SOLD Mroady door sills
    SOLD Mroady cluster
    SOLD Mroady seats (broken belt keepers, w/ bushings done)
    SOLD
    M center console, including:
    · shifter chrome ring & "fasteners" with shift boot
    · volt meter & oil temp guage
    · HVAC controls
    · All switches, as is
    · e-brake boot & handle
    SOLD ZHP shift knob (5sp)
    SOLD chrome door handles (pair)
    SOLD Driver door airbag tab
    SOLD Driver air vent w/headlight pull
    SOLD Z3 specific OEM alarm (complete with brain, one remote, Siren with plug, Light and Microphone that mounts behind the armrest, can provide the panel if required)
    SOLD SRS computer (under center console)
    SOLD Soft top hydraulic system
    SOLD M Pedals
    SOLD Glove box
    Photos provided on request
    Apr 2012
    Houston, TX
    2002 M Coupe
    If you can be persuaded to part with the Mason clutch pedal, I'm your buyer.
    Sent from my iPhone using BF.com
    ___________________________________
    Always looking for my next
    ///M Coupé...
    San Antonio
    Z3M Coupe & Roadster
    What size is the sub 10? What are you looking to get for the sub box in the trunk?
    Jul 2014
    New York , Connecticut
    2002 x5 4.6is
    im interesred with the Shift knob, center console, cluster, hardtop mounts
    Feb 2001
    atlanta
    1995 BMW M3 Race Car
    Interested in both seats. Would love photos and quote to freight them. PM me when you're ready.
    Las Cruces, NM
    3000GT
    Is there no way of fixing it without parting it out? Is there a lot of frame damage?
    Steffen Sparks
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    Quote Originally Posted by sitdownrando View Post
    Highly doubt it, but you'd be second in line already. Ha
    Quote Originally Posted by jajou318 View Post
    Looked like a 10 but I didn't measure it, I will price it out today and list it. Box looks to be a combo of MDF and fiberglass from just looking at it, but I'd have to dismount the sub to be sure. No clue on how it mounts yet.
    Quote Originally Posted by x53estoril View Post
    Mounts are staying with the hardtop unless I have a buyer that does not need them.
    Shoot me a PM with your shipping address and I will price and get a shipping quote for the rest of the parts you are asking about. Did you want everything included in the console (armrest, gauges, AC controls, shift boots, shifter trim)? The boost gauge, defrost button, bass knob and alarm light/mic are staying with their respective part "kits", but the rest of the switches are up for grabs, I may have the parts to repair the AC/recirc switch to get it complete, but have to check.
    Quote Originally Posted by ///Maniac View Post
    Never had any experience with this and recently heard grey hound will not cover any damages to car parts that are freighted, do you have a carrier you prefer?
    Quote Originally Posted by puffin04 View Post
    Right front frame rail is almost completely severed off the car, I hoped for a possible repair, but unless its a fresh shell I wouldn't trust it.
    Feb 2016
    Broomfield
    97 z3
    Interested in your side mirrors if they are still available. Thanks!
    MD/DC/NoVA area
    00 MCoupe / Audi B8 A4
    I'm very interested in the Trans. Please.
    Also, how do the front brake calipers look?
    Oct 2014
    Hartford
    1999 M Coupe
    Virginia? Connecticut here, but interested in the hardtop and install hardware. How is the condition? Price? If we can work something out, I'd drive down and get it.
    1999 BMW M Coupe
    2002 BMW M Roadster
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    Quote Originally Posted by TOMz3 View Post
    They are, working on getting them priced now
    Quote Originally Posted by BMWBergy View Post
    Collin is talking about the trans as well, I PM'd you on Face book. Price is listed.
    Quick glance looks like the front brakes are good. Would be sold as knuckle, rotor, caliper, pads, and SS lines "kit"
    Quote Originally Posted by 4Driver4 View Post
    Hardtop looks to be good to great condition. Not 100% sure on fasteners, but the mounting brackets are there and the plastic covers. Would include the wiring and defrost switch as well. No sign of the "install tool" but the tool kit and fasters are common on FleaBay for <$50. Pricing was updated in OP
    Dec 2011
    Charlotte, NC
    00 Evergreen M Coupe
    I know you are keeping the exhaust, but what is it?
    WTB: Z3 M Coupe - G-Power front splitters, driver's side door panel, ZHP lighted shift knob 5spd
    WTB: E36 M3 Coupe Street/Track Suspension, Aftermarket door cards, CF Roof plug
    MD/DC/NoVA area
    Quote Originally Posted by robb1887 View Post
    Ok. I won't have access to my phone again for about 5 hours. I guess Collin wins.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E39/2 E46
    Ah, my twin. Guess I will come over and vulture sometime soon. Put me down as a possible on the headlights for Di's coupe, if they are the black ones.
    /.randy
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    Quote Originally Posted by jdmaflac View Post
    Racelands to catless 2.5 mid pipe with cross connect, some resonators, to 2.5" v-banded Vibrant cans. I'll likely throw in some cats and bungs to make it pass inspection and rock it. I may have a set of Raceland headers and 3" y-pipe collector FS soon if I go this route, from Mindy when she was supercharged so long ago.
    Collin wants to pay Friday.
    Quote Originally Posted by rf900rkw View Post
    I'll be home all week. Adam is likely coming this weekend to get the motor if the weather holds. Headlights are the black ones as you can see in the photos, I believe all the tabs are still in tact
    Feb 2016
    Broomfield
    97 z3
    Thanks! Ill check back in a bit.
    Feb 2016
    Broomfield
    97 z3
    Sent you a PM.
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    Items are selling:
    Side mirrors
    Driver vent w/headlight pull
    All SOLD
    Updated pricing on door pulls and headlights for reasons noted. Photos to follow soon.
    Nov 2010
    Cincinnati
    S52 M Roadster
    Where was the sub box purchased new?
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    Quote Originally Posted by Marcumac View Post
    No clue.
    San Antonio
    Probably custom. I'm going to have to pass on the sub box. Thanks anyway Rob
    Oct 2013
    Tennessee
    2000 M roadster
    sad pics... amazing it can't be brought back from the dead....
    at any rate, any thoughts on the aluminum heat shields underneath? condition?? asking price?? (an if unavailable, any ideas on where to acquire some)
    and also, in the first photo, the brackets under the drivers side that hold/capture all the lines and wires running fore and aft, there are two...
    Interested in them.
    Aug 2011
    Newport News, VA
    1994 BMW 325is
    I'm local and need a cluster. I can pick up on Saturday morning if it's not claimed already.
    Oct 2007
    Chesapeake, VA
    00 Mshoe
    You said something about needing some other stuff and were going to get up with me, we could probably work something out
    Quote Originally Posted by crashgordan View Post
    Interested in them.
    Passenger "trumpet" frame rail is almost completely ripped off, and past my skills, but I can make a good dime on the parts so that's the way we are going. Mroady's are too common to try and repair something this bad that may have more hidden.
    All are there as far as I know, and are definitely for sale. I'll get them removed this weekend hopefully, priced and get up with you. Brackets shouldn't be an issue either.
    Quote Originally Posted by nbenson View Post
    No one yet, but it's first come first served. I can have it pulled by then if this rain stops long enough.
    Jul 2014
    2002 x5 4.6is
    z3m
    my zip is 06851
  1. Fs 99 m3 125k part out
    By Hitmachine101 in forum 3 series & Z Series
    Last Post: 04-04-2011, 08:53 PM
  2. Fs Supercharged 99 M3 *or Part Out!
    By NMT in forum 3 series & Z Series
    Last Post: 09-29-2007, 05:02 AM
  3. FS: Parting out Silver sedan
    By scrapz in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 08-08-2005, 02:50 AM
  4. FS: 1988 325i convertible parting out
    By nobu in forum BMW Cars For Sale / Wanted (Panjo)
    Last Post: 11-03-2004, 10:50 PM
  5. FS: 99 M3 stock parts
    By blueStreak in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 02-09-2003, 01:17 AM
