hey everyone ive recently had to get my e30 towed away after hearing a rough sounding rattle in the engine bay
i stopped the car and opened the bonnet and it sounds if a bolt were to get stuck somewhere and rattle constantly
not sure if bottom end bearing or cam rods wouldnt have a clue
any help is appreciated
thanks
Lil E30 Kid
Welcome!
Is it coming from *inside* the engine or could your fan be hitting something for example?
If from inside the engine it could be a broken rocker. You'll be running on 3 cylinders, resulting in quite the loss of power.
Take off the valve cover and see if you find a piece of metal wandering around there.
thank you i will be sure to look at this, i appreciate the advice
yes it sounds like it is *inside* the engine itself
Well whatever it is, if it sounds like it's inside the engine then don't start it again to get another listen. I have no idea how easy or hard it is to pull the oil pan on an M40, but that might be a good idea also. Was there an oil pressure light at all? Temperature okay? Any other symptoms?
Interested in vintage cars? Ever thought about racing one?
Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
Elva Courier build thread here!
my oil service light has been on for awhile but has been done but light stays on, no overheating at all temperature is stable.
i havent noticed anything else besides this rattle sound.
i will check out the oil and some others just to check if there is anything else wrong or that could be causing the problem
thanks for your help
yeah ive watched some videos of how to reset it just havent got to it yet :p
