Page 29 of 34 FirstFirst ... 419202122232425262728293031323334 LastLast
Results 701 to 725 of 832
Thread: An N/A guy looking to the darkside. Help me build boost!
  1. #701
    Sep 2008
    Toronto, ON
    6465 328ti
    Quote Originally Posted by Da Infammus 1 View Post
    So euro 6 speed and stock ZF have the same input shaft, correct?
    bingo!
  2. #702
    NY/FL
    '08 G35S, '98 M3/4/5
    Quote Originally Posted by e30kid89 View Post
    bingo!
    So same tranny, susceptible to the same failures but just one more gear?
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
  3. #703
    Sep 2008
    Toronto, ON
    6465 328ti
    You talking about the 5speed ZF and euro 6 speed?
    Not the same at all, the Euro 6 speed is the same transmission used on the e46 m3s, only difference being the input shaft. They are both classified as the Getrag 420G.
  4. #704
    Mar 2012
    Renton, Wa
    98 m3
    Yes
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  5. #705
    NY/FL
    Ahhh ok, got it. E46 M3 tranny with an e36 ZF input shaft basically. Are the euro 6 speed and e46 M3 getrags rebuildable?
  6. #706
    St Pete, FL
    99 M3
    Anyone have any luck getting a rallyroad 52mm pod? Been trying to order one since before Christmas and it's been sold out.
    FYI, I emailed Eric yesterday, and he said the 52mm pods are at the anodizer right now. It should be about one week until he has them back in stock.
    99 M3
  7. #707
    NY/FL
    Quote Originally Posted by m3leistung View Post
    Thanks! I had already emailed him so hopefully he gets back to me so I can scoop one up
  8. #708
    NY/FL
    For anyone else that was waiting, I ordered my Rally Road steering column gauge pods after speaking with Eric. He had some 52mm ones come in and will have another order later this week delivered, so if you need em I'd order em now.
  9. #709
    NY/FL
    Finally starting to make a few moves.
  10. #710
    NY/FL
    The saga continues.
  11. #711
    Mar 2013
    Upstate NY
    M3
    Sweet whens it ready for 20lbs? Glad to see some progress on this.
  12. #712
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Keep on keepin on
  13. #713
    NY/FL
    Quote Originally Posted by Mklock View Post
    When it's together it should be good for 30lbs lol. But I'm gonna start slow, work out the kinks, and then turn it up. Gotta be ready for the FL2K competition coming to town.
  14. #714
    Manchester, N.H.
    96 332IS 6466 turbo
    20# will scare u.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  15. #715
    NY/FL
    20# will scare u.
    Unfortunately I doubt it lol. Been in and driven a lot of fast cars. I'd probably be more scared to crash my expensive investment lol.
  16. #716
    Manchester, N.H.
    96 332IS 6466 turbo
    You car on full tilt will have the acceleration of an 8.5 to low 9 second car. Granted being able to pull that off is all out the hole. But the acceleration will be the same with traction.
    1996 332IS
    Built 3.2
  17. #717
    NY
    skateboard
    I like
  18. #718
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Yes, after 2 weeks will be slow again.
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  19. #719
    Boston, MA
    E36 M3 Turbo
    Quote Originally Posted by Matutino View Post
    And this is why we keep coming back for more
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  20. #720
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by SCapelo View Post
    Same reason you're buddies all tell you not to stick it in crazy...
    And you stick it in the craziest chick you find anyway.
  21. #721
    Vancouver, B.C., Canada
    '97 M3
    Quote Originally Posted by rajicase View Post
    Same reason you're buddies all tell you not to stick it in crazy... And you stick it in the craziest chick you find anyway.
    The crazy ones are awesome, a great short term solution.
  22. #722
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by chikinhed View Post
    Unless in a drunken stupor you give one your phone number.......
  23. #723
    '97 M3
    And you leave your laptop at her house?
  24. #724
    Feb 2012
    1995 BMW M3
    And you get her pregnant.... oh boy
  25. #725
    NY/FL
    That would be awesome lol, I'd love to own a car able to do that.
  1. New to the Forum - Help Me Save My Bimmer!!!
    By PoisonBimmer in forum Georgia sponsored by Harrison Motorsports
    Last Post: 06-18-2010, 09:58 PM
  2. new to the site. new to the bmw..help me out
    By deadman911 in forum 1999 - 2006 (E46)
    Last Post: 02-19-2010, 04:25 PM
  3. Looking into the 335i HELP ME
    By Smk U ltr in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-13-2008, 10:18 AM
  4. New guy back to the forums, help?
    By bmwfreak96 in forum 1991 - 1999 (E36)
    Last Post: 03-24-2005, 08:45 AM
