Well its time to let this one to someone who will have better use of it. I'm posting up for sale my 1995 #67 built E36 M3. Here is a thread with a little back ground on the car.http://www.bimmerforums.com/forum/sh...h-N-A-goodness
Some of details for those who do not have the time to read the entire thread:
Engine:
79K miles at the time of the swap. Currently at 81,500.
-Dr.Vano exhaust hub upgrade
-Vano's hardware replaced
-Timing chains replaced
-Oil pump chain replaced
-Tensioners
-WPC treated rod bearings
-ARP rod bolts
-Schrick Cams 280/272
-Alternator
-Castro Motorsports csl type intake
-Ebay ss rep headers
-E46 m3 section 1 with added resonator to cut down on the rasp
-E46 m3 section 2 mated to a UUC corsa muffler
-z3m s54 radiator
-E46 m3 oil cooler
-New Water pump
-New thermostat
Trans/Diff:
-120k mile trans
-Detents replaced
-input shaft seal replaced
-New shifter bushings
-fresh fluid
-Grip Force stage 3 clutch
-Bimmer Diffs built 3.15lsd with 40% lock, and added clutches
Suspension:
-ISC Bimmerworld coilovers (with front camber extenders)
-New front control arms
-Reinforced rear subframe(all bushings upgraded)
-Rtab bushings upgraded with limiters added as well
-Adjustable lower rear control arms
-Racing Dynamics sways front and rear
Brakes:
-Rebuilt stock calipers
-stainless steel lines from turner
-pfc z rated pads
-bimmerworld blank rotors
Interior:
-Roll Bar
-2 Spaco evo plus seats
-Mkah Motorsports door panel blanks
-Fiberglass sunroof delete
-New 5 point harnesses for both seats
-Also has stock seat belts for the streets
-A/C blows ice cold (great for driving to the track/traffic on hot summer days)
-Quick release momo steering wheel
I had this car built to be a track car/ weekend car. Its hoot to drive on the street, and even better at the track where the limits of the car can be reached.
All vins match on the car, and every panel is original to the car. I'd rate the exterior of the car 6/10 for its age. That being said here has whats been done to the exterior of the car.
-New windshield with new moulding
-New rear mouldings on the rear windshield
-New Roof Ledge mouldings left/right
-Roof painted when sunroof delete panel was installed
Another cool thing about the car is that it has a factory adjustable steering column. Car makes about 340-350whp I'd say on a dynojet. Car was tuned by RK tunes at Max Psi. The only issue currently with the car is abs light is on, and that will be addressed shortly. At the same time I will also have a euro cluster installed for the purposes of having the oil temp gauge, and higher redline as well.
I have pictures in my build thread which I linked, and can provide more after the holidays. I'm asking 17,500 for the car, and its located in Westchester NY. Thanks for looking
http://youtu.be/3B4tarRpDzQ
http://youtu.be/AkV3fc7jp3Y
― George Orwell
Huge fan of this car! I just wish I had the extra cash to jump on this. Do you by chance have any videos to drool over, such a dream. s54 e36m is the perfect combo Id like to have 2 of one day. GLWS
Glws!
Any idea what it weights?
In my thread there is a video, but it doesn't do the car justice honestly. I have another that I haven't uploaded which I can post there.
I'd like to guess 28XX lbs. If you removed the carpet, and a/c that's another 110lbs off of the car. There is weight to be saved if someone wanted to go with a single 3.5 inch exhaust as well. Maybe another 20lbs?
― George Orwell
Sunroof Delete
Spots of clear peeling.
I replaced the head lights since that last picture.
― George Orwell
Pre New Years bump
― George Orwell
Good deal for someone.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Blip
― George Orwell
Price drop 17,500
― George Orwell
Blip
― George Orwell
Small video clip
http://youtu.be/m_3T0saQX-I
― George Orwell
Blippppppp
― George Orwell
Bump .
― George Orwell
Derpp
― George Orwell
This car is awesome. Too far away for me, and I might have trouble bringing it to CA (although that swap is legal, if it's done with stock cats and everything, or close to).
Bump
I've talked with the owner regularly during the build and seen the car at bimmerfest and its done right with meticulous attention to detail. I'll say it again Gjon, don't sell it man....
Blip
Price reduced 16,500 obo
― George Orwell
Bump price reduced 16,000
― George Orwell
13,999 bump
― George Orwell
Sent you an email to your aol account
Ready for a new home
― George Orwell
