I haven't used it and probably would but you want a comment so I'll put one out there and maybe it will get you more. The inner profile is a cylinder. It was some Bosch study that I read that said square inner profiles are less prone to pulsation. Most aftermarket rails I see have a round inner profile so take it with a grain of salt.
I use an obd1 rail.on my obd2 car.
Spent some time trying to fit my turbo.
It's gonna fit but it'll be damn tight. I ground some of the rib off and my flap wheel crapped out so I'll be back at it tomorrow. But that rib will have to be ground flush and it'll fit with <1mm clearance between the block.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I used a China rail but had to mod a little. It came with 8an ORB fittings that I changed to 6an and also bought viton orings of the CORRECT size because they supplied ones that were totally wrong. I used an 8an ORB/90 degree elbow to 6an fitting on the rear to clear the firewall etc otherwise there was no hope in the e30. It also needed me to make mounting clips. Otherwise it was a nice bit of kit.
1989 E30 - M50B28 Turbo - ZF 8 Speed
You sure? IIRC all e36 have a jet pump. The OBDI cars just had one that was better than OBDII. From what I remember, the OBDI jet pump pushed the fuel back up and out of the unit on the drivers side and had a hose external to the tank to move fuel over to the passenger side. OBDII on the other hand also has a jet pump, but it transfers fuel over to the passenger side using a hose internal to the tank.
https://www.realoem.com/bmw/enUS/par...6-BMW-M3&mg=16
The above link supports what I'm talking about. The link is for OBDII and has part number for the applicable parts, but then also shows the OBDII parts
Sent from my SM-T707V using Tapatalk
which exhaust wheel did you get?
I looked a couple pages back but all i saw was D sucking and butt fingering
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
1996 332IS
Built 3.2
Powertrain: Big Bore 87mm S50| Boost Logic Gen 2 Mani | BorgWarner S366 | CP 8.5:1 pistons | Eagle Rods | O-Ringed block | Tial 50mm | Precision 46mm | LINK G4 standalone | ZF| F1 stage 3 clutch/15lb ltwfw| UUC Black TM/E| Vorshlag MM's | 3.23LSD w/AKG race bushings| AKG race subframe bushings| 'Bear Motorsports' Re-enforced subframe | Walbro 525lp fp| VPD pulleys| 4'' DP into 3.5 straight pipe"||
Handling: FK konigsports| '95 M3 strut mounts| Rogue Engineering RSM's| UUC RTAB's| 20mm front spacers| 2915lbs Full interior
Aesthetics: M3 bumpers| 18''x 8.5/9.5 BBS LMs| ZKW's| 50w 6000k HID| Smoked Corners| 50% wndshld/5% all around| M3 sedan seats F&R| Black headliner| Black/Grey suede door panels| ZHP knob| M3 steering Wheel|
1996 332IS
Built 3.2
1996 332IS
Built 3.2
1989 535i - sold
1999 M3 Tiag/Dove - sold
Its a 7.25 twin disc similar to the Tilton and Quartermaster which are kind of a standard modular format for circle track, road race, rally, and some street applications
Yea but it sounds like the discs are 3 pucks, which is probably going to make it incredibly grabby.
Id run it if you already have it tho
I think I would call tilton or comp and see if there is a more streetable disk option to put in it. The discs are super cheap
A multi plate triple disc would be fun, I have a single plate ceramic 3 puck unsprung with an aluminum flywheel, I actually enjoy it.
Is this thing running yet?
