Results 1 to 4 of 4
Thread: Question about trickle charger.
    Nov 2010
    San Francisco
    2003 BMW 330ci
    What's the best practice to use a trickle charger? I have a E46 and a E53. When using one I don't use the other sometimes for 2 weeks at a time. When I start the cars after a while the battery seems low as if it has been draining. Is there a battery charger that works for both. I am also interested in using a solar charger if possible. Thanks for your help.
    AL
    98 M3 sedan
    Quote Originally Posted by trackerxx99 View Post
    I use the BMW trickle charger and bought it off amazon for cheap. I charge if car isn't driven for 3 or 4 days. Nothing kills battery life more than decharging it over and over
    98 M3 sedan
    Feb 2001
    Fort Lauderdale, FL.
    2020 X3M Competition
    BMW electronics pull alot even when it sleep mode ... I want to say the 7er user manual says if you plan to park the car for more than a couple of days a charger is required. IE, don't park it at the airport for more than a day or two if you plan to drive it home.
    Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
    Mar 2015
    Texas
    Landrover
    Quote Originally Posted by Kevlar View Post
    Actually the older cars have a higher amperage draw. The E series cars range from 40 to 50 milliamps and F and G series 9 to 22 milliamps. You can use a trickle charger. You must hook up to the power terminals under the hood if you have a E90 or newer vehicle if it has a IBS sensor on the batteries negative terminal. I have seen a solar charger used on some models that plug into the obd2 plug.
  1. Trickle Charger Questions
    By ebod in forum 1983 - 1991 (E30)
    Last Post: 04-16-2015, 10:47 PM
  2. Quick trickle charger question
    By luciano136 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-08-2012, 02:48 PM
  3. Question about Turbo charger?
    By The Buccaneer in forum 1983 - 1991 (E30)
    Last Post: 01-04-2010, 07:16 PM
  4. Replies: 4
    Last Post: 11-18-2003, 05:30 PM
  5. Question about Super Charger / Turbo
    By Dark Star in forum Forced Induction
    Last Post: 07-14-2003, 06:34 PM
