Results 1 to 10 of 10
Thread: Dealer service with battery change
    Nov 2015
    Souderton, Pa
    BMW 2014 528
    I have a 2014 528 and my local dealer said they will and did change the battery when they change the oil. I called another local dealer and they said the battery does not routinely get changed at oil service intervals. Does anyone else have any experience with this. Thanks
    Michigan
    2005 325Xi
    It should get replaced under the Maintenance Program at at the 2nd oil service.
    From BMW ...
    I highlighted your vehicle in the list below, Your vehicle is an F10 with an N20 engine ....
    SUBJECT
    BMW Maintenance Program: 12-Volt Battery Replacement Measure
    MODEL
    E70 (X5) Produced from 4/2010 to 6/2013 With the N63 engine
    E71 (X6) Produced from 4/2010 to 6/2013With the N63 engine
    F01 (7 Series Sedan) Produced from 3/2010 to 6/2012With the N63 engine
    F02 (7 Series Sedan LWB) Produced from 3/2010 to 6/2012With the N63 engine
    F04 (ActiveHybrid 750i) Produced from 4/2010 to 6/2012With the N63 engine
    F07 (5 Series Gran Turismo) Produced from 9/2010 to 6/2012With the N63 engine
    F10 (5 Series Sedan) Produced from 3/2010 to 6/2013With the N63 engine
    F12 (6 Series Convertible) Produced from 3/2011 to 7/2012With the N63 engine
    F13 (6 Series Coupe) Produced from 3/2011 to 7/2012With the N63 engine
    E71 (X6) Produced from 7/2013With the N55 or S63 engine
    F01 (7 Series Sedan) Produced from 7/2013With the N55 or N63T engine
    F02 (7 Series Sedan) Produced from 7/2013With the N55, N63T, or N74 engine
    F06 (6 Series Gran Coupe)Produced from 3/2013With the N55, N63T, or S63 engine
    F07 (5 Series Gran Turismo) Produced from 9/2013With the N55 or N63T engine
    F10 (5 Series Sedan)Produced from 7/2013With the N20, N55, N57, N63T, or S63 engine
    F12 (6 Series Convertible)Produced from 3/2013With the N55, N63T, or S63 engine
    F13 (6 Series Coupe) Produced from 3/2013With the N55, N63T, or S63 engine
    F15 (X5) Produced from 8/2013With the N55, N57, or N63T engine
    Information
    This bulletin outlines a customer satisfaction measure that has been designed exclusively for the BMW vehicles listed above. It
    involves the replacement of the 12-volt battery as a preventive maintenance measure.
    This 12-volt battery replacement measure is:
    • Effective for repairs dated on or after January 1, 2015.
    • Applicable to vehicles that are still covered by the BMW Maintenance
      Program. This program is valid for 4 years or 50,000 miles, whichever occurs
      first.
    • The calculation is based on the current date of repair. It is
      “applicable” when the 12-volt battery was not replaced within the last 12
      months. You can then perform the battery replacement as outlined
      below.
    Please check the warranty claim history for the specific vehicle in the
    DCSnet Warranty Vehicle Inquiry to confirm the battery was not already replaced
    within the previous 12 months.
    ..... snip ....
    Vehicles equipped with the N20, N55, N57, N63T, S63, and N74
    engines
    Please replace the12-volt battery at the second engine oil service (combined
    with engine oil service counter #2) when this service shows “Recommended or Due,”
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Why is BMW replacing these batteries????
    Mar 2015
    Texas
    Landrover
    To maintain high customer satisfaction with the BMW brand. The modern vehicle has very high loads on battery and charging system. I would suspect battery failures were a significant enough area of dissatisfaction that BMW included it into the maintenance. For example the new generation 7 series has 3 batteries and several other models depending on options can have 2 batteries.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    This brings up a rather interesting engineering solution: a higher voltage (e.g., 50 volts) alternator and AC to DC converters. That way your high power sub amp can be powered by 100 VDC while the head unit can use 20VDC. Then, lithium ion batteries for storage. The 12VDC system has been with us since the 1950s! It's time to upgrade the electrical system.
    Mar 2015
    Texas
    Landrover
    BMW introduction of the lithium ion battery in the m3/m4 is probably a step to a new system.
    Feb 2001
    Fort Lauderdale, FL.
    2020 X3M Competition
    There has been lots of talk about 48V electrical systems for some time ... but nobody wants to be the first to change up the automotive world.
    Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
    Feb 2001
    Actually themes Bentley SUV has a 48 volt electronic adaptive suspension.
    Sent from my iPhone using BF.com
    Missouri
    bmw,volvo
    I have a 2011 550 (F10 w N63) that has never had a battery replaced. I'm told it's going bad and the date on it is 5/2011. What should I do? The car does have the MP plan until 100,000. They want $500 to replace the battery. Thanks
    Feb 2001
    Did you ask the dealership what they said if they would replace it? I doubt it is covered though because batteries are normally 5 year replacement where the first 2 are free of charge and the last 3 are prorated.
  1. Issues with dealer service on road trip; suggestions?
    By rlcanon in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-04-2009, 06:07 PM
  2. Who is happy with Dealer Service?
    By bimmerZ in forum Georgia sponsored by Harrison Motorsports
    Last Post: 12-15-2005, 11:51 AM
  3. Parking brake service during rotor change
    By hccyong in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-07-2002, 05:08 PM
  4. Boost changes with temp change?
    By John (PA) in forum Forced Induction
    Last Post: 04-25-2002, 10:22 PM
  5. Dealer service codes
    By Ian in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-24-2002, 10:23 PM
