Sold
1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
Stock motor
1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
build thread:
http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
If only it was for obd1!
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
1989 535i - sold
1999 M3 Tiag/Dove - sold
Gotta love how things change. OBD1 conversions used to be the thing to do. Now its the other way around....
You need to pull the cel wire from the x6031 connector and splice it into the x20 pin 8 I believe. There are a few other wires that need to be spliced into the x20 as well. Also need to add a power source for the data link connector with a 10 amp fuse and the same for the obd2 diagnostic port (the one that's located by the drivers left foot in obd2 cars. That same connector needs to have the k-line hooked up to it from the engine wiring harness (comes from the 20 pin round diagnostic port, forget what pin off the top of my head). Then the two grounds have to be grounded somewhere. I'll update the build thread soon with pics and better info soon when I have a minute. This is the thread I'll be updating:
http://www.bimmerforums.com/forum/sh...m-s-Old-E36%29
Sold
Stock motor
build thread:
