As title states. Im doing a reco on my m50b25 head and just want to know what lifters you guys have used. Ive also heard you can use vw lifters with an m50. Does anyone have info on this?
Reuse them.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
IF they are not ticking !!! If they are quiet, Butters is correct.
There are some eBay lifters for under $200. <---wouldn't trust, or OEM for $25/each or supertech for $400-500. Open your wallet, or reuse them. If one ever fails, pop the cover, pull the cams and replace. They are easy to find when they fail.
1996 332IS
Built 3.2
Hydraulic lifters almost NEVER fail. 99% of the time they gunk up, and its just a matter of taking them apart them and cleaning. If you have the money to replace them, spend the money on INA. Lifters arent something you wanna experiment with, with ebay parts.
Sheesh. I can't get rid of my litters. I have four cams worth just sitting in a bucket of oil....
Well i have the head in bits and im taking it all in to get cleaned at a shop. Just didn't want to skimp. So just replace timing chains and guides? Everything else should be fine?
1996 332IS
Built 3.2
1996 332IS
Built 3.2
The entire engine has been taken apart. Bottom end fully rebuild/stroked
OEM (INA) or bust. They are $15 each https://www.fcpeuro.com/products/bmw...em-11321748884
M50 3.0L stroker project: https://imgur.com/a/l8owP?nc=1
Confucius say: Buy the best, cry only once.
Now is the time to get some solid lifters
