Hmm, I'll try somehow to keep it with very few words, if possible. Most people just glance over the text and not read it anyways. And the more I put, the crowded it gets and people get lost.
I was going to put the changed inpa.ini inside a self extracting .exe (like the install files to inpa pack) and have it automatically insert it into the INPA folder where it belongs.
Maybe I will make a few mods, in the self extracting exe style to make it easy for anyone. Examples would be a different EDIABAS version (6.4.7 or 7.3.0), automatic E36/E46 daten update, inpa.ini menu changes...
Unless it wouldn't help too much? I'm more or less thinking "out loud" here, to see some additional improvements, as there was some good feedback.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
I'd love to have our car come up on the main screen, and would actually prefer to learn how it's done and do it myself...but I agree that if you type up a how-to, it'll probably get lost in the noise for most people.
2001 Z3 3.0 Coupe--Sterling Gray/Sunroof Delete/5MT
It's kinda like the Linux desktop arguments. The power users like to have things configureable so they can have it just how they want it. The non users don't care, accepting what is there as "the way it is". And the people that have to support the systems desperately want everyone to have exactly the same thing.
So the .exe of the replacement config is a good idea. Everyone will have the same screens. And those that want to tinker, the root file is INPA.INI. It cascades to other files, such as BMW_ALT.ENG. All text. Mostly English. Keep backups. Tinker.
/.randy
I opened INPA.INI from the folder C:\EC-APPS\INPA\CFGDAT. This looks like the right file. Here's the text that I think applies to the Z3/E36:
F16 = BMW_ALT
F16_KNOPF = Old
F16_TEXT = Old Modells
F16_ARCHIV = SGBD_BMW
And here's the text that selects the E87 (I just picked this at random):
F9 = E87
F9_Text = E87 (E81, E82, E88) / 1er
F9_ARCHIV = SGBD_E87
The only difference between the two formats is that there is "F16_KNOPF" for the old stuff, which I think is just the text that appears on the button on screen.
So would it work to just swap these so they say:
F9 = BMW_ALT
F9_KNOPF =Old
F9_Text = Old Models (I changed this as well, I think Old Modells was a typo)
F9_ARCHIV = SGBD_BMW
F16 = E87
F16_Text = E87 (E81, E82, E88) / 1er
F16_ARCHIV = SGBD_E87
What does the first line (the one with nothing after the F#) and last line (the one with _ARCHIV) control?
F#= is the script that section controls
What it is saying is
F16 = BMW_ALT
When F16 (which is shift F6) is pressed, run script BMW_ALT
F16_KNOPF = Old
Label the button on the bottom of hte screen "Old"
Label the text on the menu "Old Modells"
I believe F#_ARCHIV is the associated source code file. We didn't get those.
Hint. Look at BMW_ALT.ENG.
/.randy
Does anyone happen to know the diameter of the stock muffler inlet size for a 3.0?
2.25"?
Example:
We replace the Z4 section on the main screen
F8 = E85
F8_Text = E85 (E86, E89) / Z4
F8_ARCHIV = SGBD_E85
with
F8 = E36/7/8
F8_Text = Z3 (E36)
F8_ARCHIV = SGBD_E36
Done.
You have a menu for E36/7/8 For Z3 under button F8.
Explanation
F8 = E36/7/8 (freetext for button at bottom of INPA screen)
F8_Text = Z3 (E36) (freetext for description)
F8_ARCHIV = SGBD_E36 (choice of database of scripts)
-Abel
Thanks bud
I added automatic Self Extracting modification to add "E36 (All Models / Z3)" to F2 button in INPA.
This is found in Section E, at number 1.
The self extracting archive replaces INPA.INI from C:\EC-APPS\INPA\CFGDAT with a modified INPA.INI that contains E36 / Z3 for Button F2. A few other common models have been moved around and added.
-F2 E36
-F3 E39
-F4 E46
-F5 E53
-F6 E60
-F7 E65
-F8 E70
-F9 E90
If you want to customize it further, the instructions are a few posts up.
-Abel
When I try to run INPA, this is what comes up on the screen. It seems like something is missing.
The laptop is plugged into the 20pin engine bay adapter and the green light is lit on the chip adapter. Any suggestions?
Reinstall all 3 packs exactly like in the instructions. What you have usually happens when the 2nd step isn't carried out.
A proper reinstall will fix it.
Delete 'NCSEXPER' and 'NCSEXPER.$$$' folders in your C: drive to make reinstall glitch free.
If you can't get it, install "TeamViewer' and PM me your number to do remote desktop.
-Abel
Ok, so I have the full menu set now, but there were a couple things that happened during the install that I'm not sure about.
Here's a screenshot that shows an warning code showing up in the DOS window. Also, there was nothing I saw that showed how to do that last part in the description about the 'serial port.reg'. Is this going to cause a problem?
The DOS (command prompt) window is supposed to come up, it sets up the OBD cable.
Regarding the serial port.reg, double click on it to add the correct FIFO buffer settings to the serial port, as it is not configurable with the newer drivers. Not entirely necessary, but it helps in some cases.
You can always add the serial port.reg to the registry at anytime.
Now if you want to add e36 to your front screen menus, try adding the automatic mod in section E.
-Abel
So I have my software installed and all seems well. I'm still awaiting my cables. Cruzing around in INPA, I can find all sorts of different models except an E53? Do I use E39 for an E53?
~Mike
Go to Section E of the first post on this thread and look at the automatic modification to add Z3 (and E53 is also included) to the main menu.
Those are all configurable, which chassis shows up and not.
(but yes, E39 would also work, but it may not have all the modules listed)
-Abel
One of the late night sessions at ZFest last weekend was configuring a recalcitrant INPA installation. We finally traced the issue to the 16-20 pin adapter. I finally got a chance to look at the "bad" adapter. Turns out TxD2 isn't wired up at all. Since this particular installation was from an eastern European country, I'm guessing they used an adapter that didn't take the US-centric TxD2 line into consideration.
So if you have an installation that gives an error 0009 with the 20pin, but connects to the DME okay with the 16 pin, open the adapter and bridge pin 17 to 20.
/.randy
A few months ago when I checked one (of a few) 20pin adapter with my 328, it did exactly that, DME only reached with the OBD port. Thank you for that update, I will go back and make sure it is set up correctly.
The software pack was from the Romanian ebay seller that is making a lot of money selling a fairly well put together DIS pack? I've seen it installed, it was fine.
-Abel
Sounds like the same package. Nice little launcher front end?
/.randy
Yes that one. He's made himself rich with selling bootleg software in a nice package.
Unfortunately it doesn't allow some customizations, like adding NCSExpert that runs on 64-bit, etc.
-Abel
Cables came today. I tried using them on my e38 and kept getting the 0009 error through the 20 pin. Tried the obd, same thing. Then I tried the same on my Z with the same results. The battery and ignition are not highlighted (black) on the main screen.
So, I double checked the properties, they are set to com1 with 1 milliseconds.
Double checked that the edibas obd was on com1. Same results.
I just did the cable mod, soldering pins 7&8 together and then programming.
Now I'm getting 0018 initialization error. Both through the obd and 20 pin.
Help!!
~Mike
Unplug cable, restart computer. Plug in cable still making sure it's COM1, and run INPA. You should get one or two black dots lit if your cable is reaching INPA.
Then when it all works, with ignition on, diagnose car.
Also make sure you ran "C:\EDIABAS\Hardware\OBD\OBDSetup.exe"
-Abel
Ok so whatever reason device properties is stuck on com8. So I switched edibas to com8 and got two black dots.
Now im back to the 0009 error on my Z and the e38 on both ports.
So everything is on com1 now, but I'm getting the same results. No matter what I plug into, I always get "0009 no responce from control unit."
~Mike
Is the key on II?
/.randy
No
is it supposed to be
That was it!!!
~Mike
-Abel
