I'm working my way through this on a windows 10 laptop using the cable listed in the OP. I had to manually change the OBD.ini file from Com1 to Com3 to match my laptop to stop getting an INF-0018 error. Does this make sense, or did I just create another problem for myself? I have some some non-related issues that are keeping me from testing this fully on the car right now.
So in device manager, your USB Serial Port is listed as COM3? (This has nothing to do with USB port location on your computer, it's all in the settings)
Also in device manager, what driver version is installed to the cable? I've seen issues with drivers newer than 2.12.00 with some cables, while some work just fine with the new Windows provided one.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
Yes, the cable shows up on COM3, and when I went through the install process, I changed the setting to COM3 per the instructions. However, the OBD.ini file had COM1 on a line before a bunch of other stuff, so I changed that to 3 and saved it. It got me past the 0018 error, but I haven't tried the car again yet.
The driver comes up as 2.12.24.0 in the device manager
One other thing that might be important: Nothing happened when I did the step 3 part. I ran it in XT Serv. Pack 3 comparability, as an admin,but nothing seemed to happen. When I would start INPA, there were no tabs to click on. (Well, F1 and F10 only) I was poking around, and still had the data loader executable from the last version in my download folder, so I ran it, and got the command window that is described in the instructions. From then on INPA had model tabs to click on.
Thanks for all the work you have done on this. I'm in over my head on this, and wouldn't have made it this far without your instructions.
Your com port change will have fixed your connection errors.
Thank you for reviewing the bold part. I will rebuild the 3rd step again, with a newer/alternative method that doesn't have issues in win10. I have no win10 computers (by choice), so I don't have a good way to verify.
Please see the new updated pack "INPA 2016 Pack V1.2", with updated Part3 data loader/extractor. Hopefully works flawlessly with Win10.
You would have to repeat everything from step 1 to get it just right. (of course verify your COM port number again at the end)
-Abel
Hey 328, can any tools that you've included refresh an airbag module that has been deployed before? Or do I need to send it off to a specialized service for that?
I located a used module that matches the production date and options to my Z3, but it's salvaged from a crash vehicle where the bags were deployed. Thanks!
No, these tools in this thread will not refresh an airbag module.
One deployment may be enough for "Crash data stored" codes on some cars, so unless you actually go and read errors on the module, it will not be worth it.
Additionally this model's airbag module is the harder MRSZ3 by Temic... which can be cleared only by reading the eeprom chip on the mainboard, instead of the usual way via diagnostic port.
I would have otherwise been happy to clear them for you. But on board reading is much harder, and not worth it, if the module can be found at ~$50.
Just tried it now on my Z3 '2.3'
For curiosity's sake:
Here is a read off my older M Coupe that I just did,
MRSZ module
Also here is an example someone sent me of what crash data can look like. This is an MRS3 module from a different bmw, but the idea is the same. The rightmost hexdump has crash data written.
Attachment 552565
-Abel
I forgot to mention, I used an aftermarket tool called Carprog to read the airbag units. It is an EEPROM chip tool for airbag modules, instrument cluster, immobilizer, radio, etc. Definitely not BMW Standard Tools. The airbag module is technically not flashable/updatable, well as intended by BMW.
-Abel
Just got this running on an ancient WinXP machine and install went fairly easily. A couple notes and a question:
- The cables you recommended worked perfectly and seem to be good quality.
- I didn't know the administrator password so just installed everything as a user and it went fine. My guess is the same couldn't be said of Win7+.
- In INPA I couldn't access the cluster from inside the car but could get it under the hood. (Looking back through your instructions you seem to have already pointed this out. RTFM.)
NCS Expert loads and I can select a profile but trying to sync with the computer prompts a vin input which returns "VIN is faulty" error. Any idea what's going on? Forums seem to indicate it's a missing car data thing but I ran the LoadData.exe and that seemed to go fine.
Edit - Another issue, when I go into engine diagnostics in INPA I get an error "Versions do not match. Malfunction possible!". It seems to read everything ok, though. Is this because I have conforti program on there?
-Abel
First, thank you 328 Power, for putting all this together and answering questions. You must have saver this community thousands of dollars in diagnosis and misdiagnosis problems. Not to mention all the other technical advice.
I seemed to have installed everything ok, and I've got the OBDII to USB cable and adapter that was recommended in the first post. The OBDII connector lights up when plugged into the OBDII port.
IN PA fires up just fine, and there are two tiny black dots that flicker in the upper left, vertically. But it doesn't indicate battery or ignition on the start page. Attempting to connect yields the 0018 initialization error. This is all while the engine is running.
The adapter and INPA are both set up to use COM 11. Adapter timing is set to 1ms.
It looks like I am so close! Any advice greatly appreciated.
Try any com 1-9 first. I don't think INPA likes 10+
-Abel
Ok, now I've got both INPA and the adapter on port 2 (I heard there could be conflicts on port 1, and got a 0009 error on that port). With the car on, through the OBDII port, I've still got a 0009 no response from control unit and no battery or ignition indicator.
In C:/ediabas/bin, I've got ebas32.exe running on Windows XP SP3 compatibility, with admin rights. I've also got INPALOAD.exe and INPA.exe in C:/EC-APPS/BIN running in XP SP3 compatibility with admin. Is that proper or necessary?
**edit**
Hold on! Hold on! It's working!!!
I had the cap off of the round 20-pin port under the hood. Apparently it didn't care for that much, when you're trying to talk to the OBDII port.
Sort of makes sense when you look at the cap to the 20-pin port. There's pins actually sticking out, like it's supposed to make an electrical connection when closed.
Yes, the cap bridges the TxD2 line to the OBDii port. This is done so you can't have two competing scanners on the same serial line... too much smoke would escape doing that. Port 1 (20 pin) is primary. If it is closed and the cap on, data line is passed on to port 2 (16 pin)
/.randy
Yes, but to reach an airbag module, it is necessary to use the 20 pin port.
-Abel
Just adding a small FYI.
I did the INPA install remotely for someone on Windows 7, and I didn't manually add Environment Variables (the Standard Tools 2.12 installer does this automatically), nor did I do the computer restart, and it worked just fine.
-Abel
Looks like I found PANDORA BOX!
For long time I am looking for INPA which I can install on Windows 7 comp. My old with XP dead last summer.
Therefore I would like to clarify a few questions:
- Does it works with K-DCAN cable, INPA compatable? Or I have to buy VAG cable.
- Does it works with E91 , E70, E65 and other similar models?
Thank you advance for answers.
Yes it works with K+DCAN INPA cable.
VAG cable (with internal pins 7&8 bridged) is my preference for cars older than 2007, but K+DCAN (with 7&8 bridged) will do the same.
2007 and newer REQUIRE K+DCAN cable (without bridging of 7&8).
My pack works with any BMW 1996 to about 2011, and maybe even slightly newer. It's not perfect, but pretty good.
-Abel
328 Power 04 you are great Man!
Thank you.
After reading installation instruction I got another questions:
- How it is friendly with other car diagnostic software, for example StarCom (Mercedes), Consult (Nissan) and support information system like TIS, WDS ...?
- Can I install in designated folder on other than C-drive ( D-drive) or only in C-drive but designated folder ( C:\ BMW Diagnostic\ To try not spread all files all over?
My air bag light is on and its been on since I bought the car in September 2015. I have INPA loaded in my laptop and went through the process a few times trying to clear it and turn it off, to no avail. When I check codes, many are there in memory, none are active. I've done the Erase a few times but the codes remain in memory. So I'm thinking that there might have been an airbag deployment at some time, and I do not have to tools to clear the deployment memory(?) I can't tell from the INPA information if there has been a deployment.
328 Power, thanks for organizing all of this information. It has been extremely useful to me. INPA is a very powerful tool.
Can you list the codes?
There are two ways, screenshots, or copy the text:
Go to C:\EC-APPS\INPA\BIN\ folder and open the "na_fs.tmp" file with notepad. It contains your last error scan results (it's historical, so you do not have to be at the car to read the na_fs.tmp file).
Copy and paste that text here.
Or the screenshot.
Unfortunately, many errors left tends to mean that the airbag has an internal fault error. This is very difficult to recover on your model year (went through it myself) and usually requires module replacement. Used Z3 module from same year variant, same part number will work.
-Abel
Replied in PM, but copied here too for others, if curious:
It does not interfere with any other diagnostics programs. I have used DAS/Xentry and ISTA on the same computer, as well as Toyota Techstream.
About the folder location, you can try to install in a different folder, but standard operation is in C:\ ; using C:\EDIABAS\ for main connection interface, and C:\EC-Apps\ , C:\NCSEXPER\ for the programs. I haven't tested them in any other configuration, but I do know that many of the BMW standard programs depend on this location scheme. It may get complicated quickly if the settings are not set up just right.
-Abel
Many, many thanks to 328 Power 04. This is an invaluable resource.
I reset the airbag light and cycled ABS valves today after an issue-free INPA install and set up.
Question though: does anyone know the correct procedure, at least for a 2000 Z3M Coupe or similar, for cycling the various ABS valves? The INPA menu allows activating individual intake and exhaust valves for each caliper as well as running the abs pump. But I have no idea as to the correct procedure and still have a somewhat mushy pedal. A massive google and bimmerforums search yielded many who have asked the same question but no answers.
Thanks!
You are welcome.
For your problem, you should not need to bleed the ABS pump, unless you let the lines run dry completely. Otherwise the old fluid will pass through the pump with a normal bleed. I would look into the age of your rubber brake lines. When they balloon out, the pedal gets real mushy. Replace with DOT approved braided lines and do a good bleed.
If you got air into the system...
...you have come up with a good question. I have searched what a usual ABS pump does in a bleed routine, and haven't yet come up with a clear answer. It would be good to know. I see some pumps have an extra chamber that stays closed until the valves are actuated. I wonder if ours (we have at least 3 different kinds installed, though) are like this.
Possibly something like, run pump, open intake valve, run pump, open exhaust valve, run pump, close both?
If we get a clear answer, I can build a Tool32 test file that will do the complete routine automatically with one click, for each wheel.
-Abel
