Just a check in with you guys for certainty. If memory serves me correctly, the manufacturer recommended power steering fluid for my car is Dextron III. Is this the best choice? My steering is noisy at or near the limits of travel. I will be removing my intake manifold soon, which will give me easy access to the reservoir. I suspect the level is probably low, & will likely want to top off (or possibly change?) the fluid.
I know my e36 requires Dextron III.....hopefully that helps
It does, thanks.
