Originally Posted by
BenFenner
If you have enough stud, you can run whatever spacer you want. Stack them if you'd like. I say 33mm is the max on commonly available 90mm studs (even though 20mm is parroted as the "CYA" max). More than 33mm and you start to run out of threads using a standard depth lug nut.
Remember, they take no sheering loads once tightened, only tension.
As long as the friction on all of the mounting surfaces is not overcome, this is true. This is why using more spacers is more risky than using fewer. Normally there's only one friction surface between the wheel and the hub, and for every spacer you add, you are adding one surface that needs to maintain its friction in order to make sure that there are no shearing forces on the studs. For this reason, make sure that your mounting surfaces are clear of debris and especially clear of any lubricants. You need that friction, especially the more stretch you've put into your long studs (because if you lose the tension on the studs, then you are going to lose friction, and if you lose friction, you're going to bend and ultimately break the studs and lose a wheel.
I like the unicorns.
'99 Z3 Coupe - Jet Black/Black (1-of-114)
'99 M Coupe - Estoril Blue/Black (1-of-82)
'03 540iT - Sterling Gray/Black (1-of-24)
'16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
