I'm just about finished sourcing parts for this build. There's still a foot of snow in my yard and it was 7F this morning but warmer temps are on the way so my carport is about to be a bee hive of activity. I may get some flack for some of my choices on this build but I tried to stay true to my goals of the quickest spool without sacrificing too much up top. With the exception of my $17 ebay catch can, I tried to buy the highest quality parts possible. So I went with genuine Bosch injectors instead of $100 ebay injectors. No cutting corners to save $20 on a $7000 build. I bought almost all new parts but I got a good deal on a few quality used parts. I went with a genuine Garrett GT35r and a T4 .63AR turbine housing. Quick spool and Garrett reliability. Not many people list all the parts and prices. All those little fittings and gaskets and hoses....... it all adds up. So for the benefit of anyone considering a turbo build......
Special thanks to Butters for his patience and advice.
I'm pulling the engine this week. Here's my list so far
M3 Turbo Build
98 m3 vert 135,000 m50 manifold
Tune- 42lb injectors, gt35, meth above 13lbs, makes 450hp at 14lbs boost
Sachs TOB from forum $30
Misc bungs and barbed nipples eBay $25
New 6 Bosch 42lb injectors. Treperformance/ebay. $316
New TIaL 38mm waste gate from forum $250
New arp2000 head studs from forum $125
Extra ARP lube Summit $20
New CES .140 copper spacer from forum $200
Copper Spray $10
NickG dyno tune from forum $500
New NickG maf from NickG $300
Gt35r used 1000 miles $675
Max PSI Down pipe used and custom 3" exhaust from forum $1100
Used Snow Meth injection$125
New Tubing/res kit for Meth $65
Stock Head Gasket kit $85
Cutring Headgasket $275
T4 SPA manifold $400
Engine mount arm and poly bushing $150
Catch Can ebay $17
Innovate SCG-1 AFR failsafe/electronic boost control $325
Rally Road steering column gauge pod $90
Borla 3" exhaust from Summit $130
Borla 3" exhaust tip from Summit $48
Intercooler from ebay $85
TIaL BOV from Allibaba $40
Vanos adapter bolt from Summit $25
Magna Flo high flow 3" cat from Summit $50
82C tstat from Rock Auto $20
Zirgo 16" slimline fan 2800cfm ebay $100
Shift detent pin kit ECS Tuning $60
Pivot pin ECS Tuning $1.00
Throw out bearing guide tube ECS Tuning $25
Vanos orings ebay $28
Intercooler piping ebay $180
Oil feed/drain lines -4 AN/-10AN $40 Summit/ebay
Used F1 Stage 3 clutch and single mass fly wheel $300
$6235
Needed:
Exhaust manifold studs $20
T4 .63ar Turbine housing $300 (hard to find)
misc gaskets $50
Fuel pump $50
Maf flange $25
Coolant lines $10
Air filter $20
Head testing and service $300
$800
Drag radials
$500
Don't forget to add a clutch into that list. The F1 stage 3 should suit your needs.
I can provide you with a fuel pump , and some of the other misc stuff . you will have to come over one day and raid my bins.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Sorry I forgot that. I already have a clutch that I was supposed to install when I had my Supercharger.
Finally! Another turbo BMW to add to Vermont! I think that puts us at 3 that I know of. Let me know how that clutch holds up as well. It's been a while since we met
97 E36 M3 PT6870 847whp
Haha Its certainly has been a while. That clutch has been staring at me since last spring.
That looks like a good list. Is the spa drilled also for t3? If so just go t3 on the housing. If not sell it for one that is or keep searching or find out what sort of deal butters can get on an ATP t4 gt35r housing.
Sourcing that housing is the hardest part of the build. I don't have it yet. I wanted quick spool so I went with .63 but T3 on that would end up choking the engine up top so I went T4. Im told the T4 may also give me a smoother spool. The problem is a T4 .63 housing for a GT35 is very rare. Butters is looking into it for me and I may end up going directly to Garrett for one. All the T4 .63 turbine housings Ive seen are for P Trim. In the end it will only be a couple extra $$ and Ill have the exact setup I want. I may end up changing it next year but Im happy with my choices so far.
I can get you one, no problem .
T4 .63
1996 332IS
Built 3.2
1996 332IS
Built 3.2
Sweet!!
I also found this oil filter for the turbo feed line.
http://store.forcedperformance.net/P...4ANFilter.html
Great parts list. Enjoy the build. This summer is going to be great as I can't wait for all of us to meet up again soon.
1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
Stock motor
1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
build thread:
http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
The new England game strong this year!! Hope to see yours and others cars this season!!
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
Too expensive. Here is the best bang for the buck.
http://www.anplumbing.com/Accessorie...Filter-56.html
1996 332IS
Built 3.2
1996 332IS
Built 3.2
Glad I don't have a JB turbo.
1996 332IS
Built 3.2
June 1st ? You got some massive work.
1996 332IS
Built 3.2
You think 40 days is pushing it? Hmmmmm......sounds like a challenge.
Butters could do it in 20.
bruh, you got this.
Stock motor
build thread:
1996 332IS
Built 3.2
