Results 1 to 10 of 10
Thread: bucking like a bronco under hard acceleration
    Mar 2015
    Australia
    1994 BMW 540i
    I have a 1994 540i automatic. It runs perfectly at idle and under normal acceleration but if I put the accelerator down all the way the revs start jumping between around 3,000 and 3,500 cycling about twice per second and the jerking is quite violent. It does not seem to matter if the engine has been running for some time or only just warmed up. Mechanic thought it might be the flow sensor on the air intake and replaced it but this made no difference.
    Any ideas?
    McKean township Pennsylva
    1999 M3 , 1999 328is
    Is it able to exceed 3,500 rpm? IS this the only band of speeds that it bucks?
    Current fleet:
    1999 BMW e36 M3
    1999 BMW e36 328is with rotary valve engine head
    1999 Oldsmobile Eighty Eight
    1990 Jeep Comanche Eliminator
    1962 Austin Healey Sprite
    Mar 2015
    Australia
    1994 BMW 540i
    If I don't plant the foot yes, revs will go right up to redline. In normal driving it is fine. It is only when I try to accelerate maximally that the bucking occurs and even then not everytime.
    Oct 2014
    Loma Linda, CA
    1998 BMW M3 Coupe
    Are there any CELs on the dash? If so, it may be helpful to pull them. So far it sounds like coils to me
    primum non nocere
    This one has me pretty stumped. I have not experienced such a thing in any vehicle.
    It sounds like some weird fuel issue to me. Is there a possibility that your fuel filter is clogged or you fuel pump is dieing?
    Current fleet:
    1999 BMW e36 M3
    Mar 2015
    Australia
    1994 BMW 540i
    No CELs on the dashboard :-(
    This is a tough one and certainly has stumped my usual mechanic.
    MAF, plugs, coils would be the first things I look at
    PRICE CUT on ALL FABRICS
    Oct 2014
    Loma Linda, CA
    1998 BMW M3 Coupe
    Quote Originally Posted by BimmerBreaker View Post
    This and check fuel pump pressure, perhaps replace fuel filter
    primum non nocere
    Mar 2015
    Australia
    1994 BMW 540i
    Thanks. Good suggestions. Can I ask what MAF is?
    Oct 2014
    Loma Linda, CA
    1998 BMW M3 Coupe
    MAF is Mass Air Flow sensor. Every fuel injected car has it and it is located in the intake piping prior to throttle body. It basically calculates amount of air flying by and communicates this information to the ECU.
    primum non nocere
