You posted this in the E36 forum and I replied, but did not get your answer...
What are you not pleased with? Specifically, what are you looking to change or improve?
Understand that with BMWs, the final feel of the shifter assembly, regardless of brand, is significantly affected by the transmission itself. Residual free play, or difficulty getting into specific gears, are all part of what is going on inside the transmission. No external shifter mechanism can improve beyond the exterior linkage parts.
Knowing what I do about how BMW shifters work (which, I have to say, is quite a bit), you won't be able to get any greater precision than what we provide with the UUC Evo3 design.
What can improve your shifting feel further is choosing the right transmission fluid. Modern BMWs do best with a synthetic ATF (I recommend Redline D4-ATF). What I also strongly recommend to smooth out the action and even help with crunchy synchros is the LubroMoly MoS2 "Additive for Gears" product:
The MoS2 is definitely a product that over-delivers. We use it in transmissions and differentials.
NOT with that company any more.
