Results 1 to 3 of 3
Thread: Stop!check oil press
    Dec 2014
    Orlando, FL
    2003 X5 3.0
    I have received this message before in my 2002 3.0 X5. I checked the dipstick and the oil level was higher than max, so I extracted some of the extra oil to bring it to normal. Messages stopped About six months later, I received a low oil level warning message, and I added a quart of 5w-30. Two weeks later I received the "stop!check oil press" message again, shortly after I noticed smoke coming from the engine. I immediately shut the engine off and opened the hood. There is oil splatter all over the driver side engine compartment and the front driver side wheel and well. The car was towed to a mechanic. Just want to make sure I'm not going to get ripped off. I hope I'm not in for a super costly repair...
    Mar 2012
    Hopewell Junction, NY
    1987 325iS...edan
    You realize oil level and oil pressure are two separate things, right? Your motor may have had borderline low oil pressure (which is not good) for a while now, and that can cause serious damage to just about everything.
    Interested in vintage cars? Ever thought about racing one?
    Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
    Elva Courier build thread here!
    Quote Originally Posted by ELVA164 View Post
    +1...
    OP you probably are in for quite an expensive repair, because you neglected to check oil pressure when the car was telling you to.
    PRICE CUT on ALL FABRICS
