My 2005 325xi has begun to heat up slowly. I am guessing the thermostat needs replacing. I would appreciate
any confirmation or other information.
Thermostat would definitely be my suspicion. If you don't know the last time you've done it, do it now.
PRICE CUT on ALL FABRICS
It's only got 42k on it but I guess being 11 y/o anything could go. Thanks.
I would agree that the thermostat is highly suspect, and replacement should be your 1st course of action. Hopefully, that will solve the problem. If not, further troubleshooting will be necessary.
Does the car run fine other than that? You might want to check if all the headers are heating up after a cold start. Just pop your hood before you start it in the morning, and immediately after just lightly feel each header to make sure they are all heating up evenly. If the car doesn't exhibit any other symptoms, your problem is probably not here, but it's a quick and easy way to make sure you are firing on all cylinders.
The car runs great. I made an apt to get the thermostat replaced. Thanks!
