I need some advice. Bought a bmw 1 series e87 , it shows a loss of coolant overnight . I fill coolant and the next day it all leaks out , this tends to happen only when the car is in use if I leave it standing the coolant stays in the water bottle . I jacked the car up and saw the coolant dripping out from the left bottom of the engine I need advice on which part could be causing it . I also noticed a couple of times the low coolant light would come on while there still is water there.
Could be crack in expansion tank or one of many lines leaking
Sent from my iPad using BF.com
