- Ltw battery question
Just installed an oddessy pc680 and I have a 1amp trickle charger. Should I put the battery on the trickle? I don't daily the car
Please define, "don't daily the car." How frequently is the car driven? How many miles do you drive the car?
I don't recommend a trickle charger as it has no "intelligence" as to when the battery is fully charged. I recommend a battery minder.
You need a smart battery charger, like a float charger. Make sure the charger you use is compatible with your battery as well, especially true when messing around with non-OEM batteries
- You may not post replies
- You may not edit your posts
Forum Rules
