Hey all,
Just bought my first E32 over the weekend. This thread will be for updating on the progress and repairs on the car.
_________________
Back story: My grandfather always had BMW's when I was young, around 5-10. First one I remember was his E32 740iL, white on tan. Next car was an E39 Msport 540/6 speed. I loved these cars and remember them well! So, always wanting one, I bought my first BMW two years ago: a 1995 E34 540i 6 speed. I wanted the look/style of the E32 and the performance of the E39 (needed to have a manual!).
Anyway, after much work and rust removal performed on the E34, I decided to store it for the winter and buy a winter "beater". What I purchased turned out to be not a beater at all.
I purchased a 1990 750iL, black on black. Optioned with Ski-bag, S3.15 and rear heated/reclining seats. It has 129,800 on it and runs MINT. From what I can see it looks like it has new filters, oil, coolant and radiator, not to mention not problems in the ignition or vacuum department. There is also ZERO body rust ANYWHERE. The exhaust system does have some rot (It sounds quite nice because of this, I might add) but everything underneath the car is beautiful, as well as the inner and outer door-bottoms.
The paint is overall pretty decent, the front does have myriad small rock chips. I did do some buffing today (first time with single stage paint), the results were pretty decent. I did take a few video and pictures I will post momentarily! I was, however, not able to drive it home since it has a violent highway shimmy due to a sticking front brake caliper. Car was towed home by a buddy and was delivered in excellent shape.
I do have some initial questions/issues I need to sort:
--Where is the button for the rear sun shade? I can't pull up on it much and there is a fuse for it in the fuse box.
--Have some electrical problems when it comes to the parking/taillights. The orange front corners and rear tails all work intermittently, at totally different times from eachother. I can't find any electrical correlation, all bulbs and fuses are good. Thoughts?
--My ASC light does not come on when I push the button. I see the throttles twitch when I turn on the key. I'm not sure if ASC is on or off because of this.. ASC is good for snow, but I might like to spin the tires now and again..
--Stuck front brake caliper
--Needs front windshield, many chips
--Seat twist *fixed!
Anyway on to some pics. The car runs and drives absolutely beautifully (minus the front caliper)
Upon arrival at seller's place:
Arrival home:
Some neat stuff:
Some paint work today:
Here's how swirled it was
Clay'd
A rough before and after, reflection of the garage door in the trunk lid:
Done:
I'll see if I can forward the videos I took and posted to my E39 friendz, other than that I'm excited to start driving this car!
Not going to mod this one, though I think I'll grab a set of Shogun's engine chips. Have my E34 honeycombs with blizzaks ready to go on it!
Leo
Current
2005 E55 AMG
1998 Silverado K1500
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
2001 Stratus 740i Msport
1990 750iL
1995 540i/6
1996 MGM
Hi Leo, congrats to that nice condition car. Plus two of the rare and expensive original switchblade remote controls in as new condition. Engine is a facelift engine with the oil filler cap in the front, so with Motronic M1.7 and Bosch end number 352 chips, if you want to add my chip set for the M70.
Although you have the original built sheet, here once more
Daten für die Fahrgestellnummer: WBAGC8318LDC77954
Modellbezeichnung: 750iL
Ausführung: USA
Typschlüssel: GC83
E-Code: E32 (2)
Karosserie: Limousine
Lenkung: links
Türen: 4
Motor: M70B50 - 5,00l (220kW)
Antrieb: Heckantrieb
Getriebe: automatisch
Außenfarbe: Schwarz (086)
Innenraum: (0232)
Produktionsdatum: 14.05.1990
Werk: Dingolfing
S209A Sperrdifferenzial Differential lock 25%
S240A Lenkrad Leder Airbag Leather steering wheel
S288A BMW LM Rad Kreuzspeiche 29 BMW light alloy wheel, cross spoke 29
S439A Interieurleisten Interior trim finishers, matt chrome
S464A Skisack Ski bag
S488A Lordosenstütze Fahrer u. Beifahrer Lumbar support, driver and passenger
S494A Sitzheizung Fahrer/Beifahrer Seat heating driver/passenger
S496A Sitzheizung hinten Seat heating, rear
S640A Vorbereitung Telefoneinbau universal Preparation f tel.installation universal
S694A Vorbereitung BMW 6 CD Wechsler Provisions for BMW 6 CD changer
S818A Batteriehauptschalter Battery master switch
S925A Versandschutzpaket Transport protection package
Now to answer some of your questions:
--Where is the button for the rear sun shade? I can't pull up on it much and there is a fuse for it in the fuse box. >>According to the built sheet your car has no electric rear sunshade, should be manual. Normally the sunshade switch is center console rear , see owners manual
--Have some electrical problems when it comes to the parking/taillights. The orange front corners and rear tails all work intermittently, at totally different times from each other. I can't find any electrical correlation, all bulbs and fuses are good. Thoughts?
>>> first check the socalled mustard relay, repair is on my website and here http://bmwe32.masscom.net/
--My ASC light does not come on when I push the button. I see the throttles switch when I turn on the key. I'm not sure if ASC is on or off because of this.. ASC is good for snow, but I might like to spin the tires now and again..
>>>that I skip, electric experts have to reply to this
But you might try this: ABS/ASC blink test code
Only posible on newer E32
German version:
ABS/ASC-Blink-Code
- Bremspedal und Schalter "ASC" gleichzeitig drücken
- Zündung "an"
- Bremspedal und Schalter loslassen
- ASC-LEUCHTE fängt an zu blinken
BC = BlinkCode
BC 1 = kein Fehler
BC 2 = EMS Fehler
BC 3 = Motronic Fehler (DME/ EMU)
BC 4 = Drehzahlgeber Fehler hinten links
BC 5 = Drehzahlgeber Fehler hinten rechts
BC 6 = Drehzahlgeber Fehler vorne rechts
BC 7 = Drehzahlgeber Fehler vorne links
BC 8 = ABS-Magnetventil hinten links
BC 9 = ABS-Magnetventil hinten rechts
BC10 = ABS-Magnetventil vorne rechts
BC11 = ABS-Magnetventil vorne links
BC12 = ASR-Plungenventil Fehler hinten links
BC13 = ASR-Plungenventil Fehler hinten rechts
BC14 = Ventilrelais Fehler
BC15 = Rückförderpumpen Fehler
BC16 = Speicherladeventil Fehler
BC17 = Langzeitfehler Druchüberwachung
BC18 = Leckage Fehler (Wird auch angezeigt wenn Druckspeicher(Gaspatrone) im ASC+T Hydraulikblock schadhaft ist (zB. leer))
BC19 = Druck Fehler
BC20 = Getriebebeinflussung Leitungsfehler
BC21 = ABS/ASR-Regelgeräte Fehler
BC22 = TD-Signal Fehler (dürfte Tachoimpuls sein)
BC23 = Option pin Leitungs Fehler
Zu BC 22:
TD Signal Fehler
Regelgerät Kl. 55
Zündung aus
Stecker vom ABS/ASR-Regelgerät und Motronic-Steuergerät Bank links abziehen
Leitung vom ABS/ASR-Regelgerät Kl.55 zum Motronic- Steuerg. Kl.6 auf Unterbrechung/Plus-/und Masseschluß prüfen.
wenn i.O. = in order >> Fehlerspeicher Motronic auslesen
wenn i.O. (= in order, o.k.)>> ABS/ASR-Regelgerät tauschen
Translation, hopefully correct:
- push brake pedal and ASC switch simultaneously
- Zündung "an" / ignition on
- Bremspedal und Schalter loslassen /release brake pedal + ASC switch
- ASC-LEUCHTE fängt an zu blinken/ASC light starts to blink
BC = BlinkCode
BC 1 = kein Fehler / no fault
BC 2 = EMS Fehler / EMS fault
BC 3 = Motronic Fehler (DME/ EMU)/ DME/EMU fault
BC 4 = Drehzahlgeber Fehler hinten links/fault speed indicator rear left
BC 5 = Drehzahlgeber Fehler hinten rechts/fault speed indicator rear right
BC 6 = Drehzahlgeber Fehler vorne rechts/fault speed sender front right
BC 7 = Drehzahlgeber Fehler vorne links/fault speed sender front left
BC 8 = ABS-Magnetventil hinten links/ABS solenoid valve rear left
BC 9 = ABS-Magnetventil hinten rechts/ABS solenoid valve rear right
BC10 = ABS-Magnetventil vorne rechts/ABS solenoid valve front right
BC11 = ABS-Magnetventil vorne links/ABS solenoid valve front left
BC12 = ASR-Plungenventil Fehler hinten links/fault ASR plunger valve rear left
BC13 = ASR-Plungenventil Fehler hinten rechts/fault ASR plunger valve rear right
BC14 = Ventilrelais Fehler/ fault valve relay
BC15 = Rückförderpumpen Fehler/ fault recycling pump
BC16 = Speicherladeventil Fehler/fault storage load valve
BC17 = Langzeitfehler Drucküberwachung/fault long time pressure control
leakage fault (is also shown when pressure vessel (gas bomb) in ASC_T hydraulic block is damaged (for example empty))
BC19 = Druck Fehler/ fault pressure
BC20 = Getriebebeinflussung Leitungsfehler/fault pipe transmission control
BC21 = ABS/ASR-Regelgeräte Fehler/fault ABS/ASR regulators
BC22 = TD-Signal Fehler (dürfte Tachoimpuls sein) TD-signal fault (should be the speed impulse)
BC23 = Option pin Leitungs Fehler/option pin line fault
Zu/to BC 22:
TD Signal Fehler/TD signal fault
Regelgerät Kl. 55/ regulator terminal 55
Zündung aus /ignition off
Stecker vom ABS/ASR-Regelgerät und Motronic-Steuergerät Bank links abziehen/disconnect from the ABS/ASR regulator unit and MOTRONIC module bank left the connectors
check the line from ABS/ASR regulating unit terminal 55 to MOTRONIC- control module terminal 6 for interruption/plus-/and ground connection
wenn i.O./ in case that is o.k.,....
Fehlerspeicher Motronic auslesen/read fault codes
wenn i.O./in case that is o.k.,....
ABS/ASR-Regelgerät tauschen/change ABS/ASR control unit
--Stuck front brake caliper >>>also shown here http://bmwe32.masscom.net/
As for the paint, there you might ask the experts in this forum: Car Detailing and Show and Shine Prep http://www.bimmerforums.com/forum/fo...y-Autogeek-net
Wiring diagrams are here http://shark.armchair.mb.ca/~dave/BMW/e32/
Wow thanks shogun for all the info!
I will try the ASC blink test this evening.
I'm guessing since I don't see it listed that my car doesn't have LAD?
And yes I'll be ordering the appropriate chip set!
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
All iL have LAD as standard, so it is not listed as optional extra. Only if the car would have in addition to LAD EDC, then it would be listed as optional extra and then there would be a switch with K and S on the center console.
good looking car Leo.
Get some good lights in the front, you won't regret it.
Looking forward to your thoughts on the m70 vs your m60 I can almost feel the 12 cyl snobbiness.
Might just swap my smilies with HIDs from the 5 to the 7.
Lol I can't wait to give you my thoughts! It's definitely torquey, blasted it around my neighborhood a little bit.
Ahh very interesting, I did not know! Thanks Shogun. Price on chips? I'll get the funds transferring asap.
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
You won't regret it
http://www.bimmerforums.com/forum/sh...rwerks-adapter
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
Looks like a nice car. I am looking forward to hearing about your experiences with it.
I am always tempted to get one when I see they come up.
Current Fleet:
E34 1991 M5 Macaoblau on Complete (ruined)Leather Champagne - http://forums.bimmerforums.com/forum....php?t=1705166
Past:
E34 1989 535i 5-Speed AlpineweissII on Natur - Parted
E34 1992 525i 5-Speed Islandgrun on Pergament - Parted
E34 1995 540i 6-Speed ShwarzII on Shwarz - Sold to Sneezy.
E34 1995 525i 5-Speed Calypso Red on Parchment - http://forums.bimmerforums.com/forum....php?t=1748143 - Sold locally.
E39 1998 528i 5-Speed Black on Black - Sold locally.
E34 1993 M5 Alpinweiss on Black - http://forums.bimmerforums.com/forum...lpinweissII-M5 - Parted
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
Ah, nice to see more E34 people come over to the real luxury side.
Welcome to this side of BfC... and welcome to the V12 family.
My Current Cars:
E70 2010 X5 4.8i Xdrive Spacegrau
E90 2008 M3 6MT Silverstone II
E34 1992 M5 3.6 J-spec Calypso
E34 1990 535/5 turbo Bronzit
E32 1990 750iL Highline Delphin
E30 1988 325i M54 swapped Schwartz Convertible
No longer with me:
E46 2001 330Ci Titanium Silver
E32 1993 740iL Lazurblau
E34 1992 525iT Kashmirbeige
E34 1990 535/5 Cirrusblau - Former Miller Performance Stage 2 Test Mule Car
E34 1989 525i Cirrusblau - the Slug
E21 1981 320i w/ M20 swap Arktisblau
E21 1979 320i Turmalingrun
We all come to our senses sooner or later.
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
Didnt find really any evidence of overheating rotors etc..
Also determined by ASC is functional, the switch just operates slightly differently than my E34, right over my head!
Cars ready to get on the road! Hopefully early next week.
Leo
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
Great looking ride Leonator, those v-12's are so cool!
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
Needs replacing the dust boots and rubber dampers on the LAD dampers
2 x Additional damper, rear 33531138577
2 x Rubber boot 31321125878
On my website is a write up and also on that of Johan. Maybe even no need to remove the rear parcel shelf and reat seats to get to the 3 nuts on top, once made it by just removing the covers of the rear parcel shelf speakers and speakers
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
Looking down on the m60b40 yet
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
Beautiful E32!!
95 540i6 M Sport - 95 525it S52/OBD2 - 433k E36 328i5 - X5D that hit a pothole - IG: @justinmurray95
Thanks Justin! Just took my mom for a spin in- she loves it.
Drove it in to work early this AM to get it up on the lift before the techs get in there, front right wheel is a bear to turn by hand after driving a good 20 minutes on the highway. Driver's front was a little easier.
Also think I might have a vibration at the bottom of second gear, thinking CSB. Gonna put it back up tonight after the techs split to give everything under there a good going over.
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
Nice pickup Leo. That thing's mint, far from a beater! Hope you keep it that way.
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
