1997 Boston Green 4D 5 speed , 127k miles
Great condition, very reliable, runs and drive great. Classic E36 fun to drive platform.
Sad to see it go but I have too many cars and not enough space. All maintenance records and receipts are available from time car was new. Engine does not burn or leak any oil.
---Maintenance performed within past 25k---
Clutch
Water pump (with metal impellers)
Thermostat and housing
Coolant, radiator hoses
Water pump belt
BMW Antifreeze
Clutch slave cylinder
Camshaft position sensor
Rear trailing arm bushings (with reinforcement spacers)
Rear shock mount bushings
Spark plugs
Transmission Fluid - Royal Purple
Differential Fluid - Mobil 1
Engine oil replaced every 5-7k with Mobil 1 synthetic
The car will come with 15" bottlecap style wheels with Blizzak snow tires. Tires have decent tread, approx. 50% remaining. Includes OE 15 " wheels as well. Thule rack in pictures not included.
---The bad---
Both front windows need new regulators, will not stay on the track currently
Headliner is sagging, fairly common for these cars.
Minor surface rust bubbles forming on bottom of drive side door.
Paint on hood and roof is not great and oxidizing in areas.
Danbury, CT area.
$2200
1997 BMW 318i
2001 Honda S2000 - SCCA STR
Bump - $1900
1997 BMW 318i
