- 1980 e12 climate control
so i just bought a 1980 528i 2 hrs ago and i was driving it home the heat was on and it was hot so i turned the left dial from warm to i think past 0 ( it was dark) car started to blow cold air so i turned the dial back to about the 9o'clock spot and the air was still cold. so i moved it all the way back to warm and still no heat. crap loads of heat to no heat. did a gear or something in the climate control strip? also when i turn the dial to cold lots of air come out of the ducts but on warm air only comes from the defrost and floor. ideas?
- You may not post replies
- You may not edit your posts
Forum Rules
