Has anyone actually DONE THIS?
I have a near free e38('98 740il 9/97) giving codes 39 & 204. Cranks, no start. No fuel pressure, no spark. My research indicates the EWS and DME are out of sync. Car would start before battery was disconnected.
Given the value of these cars a tow and even a minimum diagnostic fee will make this thing a part out.
I'd prefer to get it running again but it has rust and doesn't merit much investment.
May just need a realignment. There is not an "easy and quick" way to defeat it.
If it's not just out of sync check with DUDMD he may be able to clear the DME so it can be resynced.
Trevor
01 749i sporty, build 12/00 "Sports Barge",S62
92 VW Corrado VR6,AAA
81 Delorean,B28F
81 VW Rabbit Pickup 1.8T,AWW
03 VW Passat wagon 4.0 W8 6spd
Definitely needs to be re-aligned. The trouble is cost.
It did throw a code for EWS power supply. One of the DME fuses was blown and since replaced that code has not returned. I found a bulletin that mentions loose connections in a power dist. block under the pass seat. I will investigate this today but have little confidence this will be the problem.
Thanks for the tip, I will contact DUDMD for advice.
Well the cheapest route is realignment. It only takes a couple of minutes with a diag. laptop.
Trevor
81 Delorean,B28F
+1 on DUDMD. If you had a blown fuse in the carrier, I would check your wiring loom. Pull the connector on the sensor that sits on the thermostat housing to make sure it is not burnt. Pull the DME out to make sure there is no sign moisture also.
The fuse block under the front passenger feet can cause myriad issues.
Resync takes only a minute. Even INPA can do it (worked for me).
I have some info on both in my thread in my sig.
BlackKnight530i has eliminated EWS on his S62 swap, but it basically requires code level manipulation of the DME software. I'm not real clear on the details of his work, but he knows his way around the issue pretty well, but he would have done it on the s62 DME.
There are members here that are local to you that have the software setup and would probably be glad to help. purplecty is one that comes to mind. Mind send him a PM.
I'm also interested in the removal of my EWS. My car however has EWS II and has twin DMEs so I'm not sure if this is at all possible. Hopefully somebody here can offer some info on the matter.
You might try these guys:
http://www.rmsonlinestore.com/BMW-EWS-Complete-Kit_c10.htm
Somewhere in the forums is a post that indicates the EWS will self destruct if the battery is allowed to drop below a certain voltage while the ignition is on (like trying to start on a dead/dying battery). I think that's what happened to mine long ago. $600 to have indy replace and synchronize the EWS.
Sometimes I sound like a salesman for these guys, but RPM motorsports in Canada can blank your computer for less that 600$US. I might also say, that at one time, I read almost every post online about an EWS no start, and if the engine will crank, that is rare. It is way more common for the car to do nothing than crank and not start, but I am certainly not the final word.
Sorry, just followed this link above, and I see that is the same thing I am talking about. They did an EWS removal on my car, and it saved me about a 5 month research project.
Back when these cars were valuable (usually, the day before it was driven off the lot), the EWS probably made a lot of sense. No longer was it possible for some ne'r-do-well to hotwire the car and make off with it. Ironically, the cost of repairing the EWS and being unable to delete it is starting to take more cars off the road.
eBay.
Search "BMW INPA Cable" and see what comes up. I ran the search yesterday and the stuff could be had in the states for as little as $18.
The INPA software can be found in various places on the internet, and even the software I "bought" with my cable was just pirated software burned to a disc.
If I had patience I'd be a doctor.
Dealer tech has pronounced a bad DME. I'm not convinced so barring the car being sold as is I may invest in the items suggested and give it a go. Not sure if I'm up for a part out yet but anyone needing parts can feel free to let me know via PM. It has a VERY nice black interior.
Thanks especially to daytonatrbo
Can the DME be read at all?
Yes. I am disappointed with the dealer tech. in spite of the recommendation of the BMW parts man I've known for years. These guys seldom deal with anything very far out of warranty. I'm not convinced he understands the problem and these guys don't like it when a mere customer dares to presume to know something. I suspect he wants to throw parts at it. A nice gig if you can get it. I'm prepared to eat my words.
P-city, if you are up for this, I'm game but cannot afford an experts wage for travel time. PM is best
Might be better getting a diagnostic setup and a cable and start learning yourself. Won't save you time but will save you money. You have to weigh out what is more important to you. I think you have more issues than a mere ews dme sync from the little time we spoke about the issue. Wish you the best of luck ross! Hope you get her running as i understand this is a car you're trying to sell and not keep...
