Hi, i picked up a electric rear window kit*
*minus the loom/relay, does anyone have a wiring diagram for this? i cant seem to find it in the wiring diagrams online.
The below link gives an idea where it all goes, and i can guess some wires.
http://www.brianbernard.com/BMW%20DI...ows%20Rev1.pdf
Wait what.. Rear power windows in the coupe?! What is this witchcraft?!
Or sorcery. If you chanted
option 362
option 362
option 362
for a few weeks, a New Jersey grand wizard might order them on the car.
as soon as i ask for help i find it;
search;
Power vent window - two-door model
http://www.e36.it.pl/e36/318is/obc%2...ing_Manual.pdf
Cheers guys, i am retrofiting this into a 1994 e36 m3 euro, wish me luck!
Where did you get the kit and for how much? Am looking for one myself also for retrofit purposes.
Can you not just steal them off of a vert in the scrappers?
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
It's a sweet option to have. The retrofit kit has been discontinued for a long time.
I hope it's not gonna be a problem to revive this old thread. I've a question regarding cables connection.
I'm restoring my european E36 Coupe with electric rear windows and needed to cut down a lot of cables under the driver seat and sold them since they were broken and caused short circuit back in time when the car was a daily driver.
I've a problem with soldering 2 cut cables now - red-brown - which both are going from buttons for opening/closing rear windows. One of them was connected to big blue DRM 4 relay which seems to be rear window relay and another one was connected to a small green relay. Both relays are sitting under the steering wheel and the harness looks original, however from reading the power diagram in this thread, it looks a bit different on my machine?
I'm trying to understand, if the red-brown cable from driver side rear window button should be connected to the big blue DRM 4 relay or the small green, if that matters? I'll upload some pictures soon, how it looks...
https://i.imgur.com/8tpP0YQ.jpg
The green-black and both red cables aren't tracked, however the red-brown goes down the floor to the steering buttons.
https://i.imgur.com/BRPVOtZ.jpg
6 cables here. 2 goes to buttons and 2 to windows motors on both sides, then a not tracked thinner black-red wire and finally the red-brown cable which also is going to the buttons in the same harness as the one from the smaller green Siemens relay.
https://i.imgur.com/uqgLbtH.jpg
Everything was working back in time.
I've connected the red-brown wire from both L and R buttons to the same color wire in green relay and both window motors are working. However the red-brown wire from the blue DRM relay isn't connected at all, it hangs insulated right now and as per the power diagram, it should be connected to the green relay, but isn't.
How does both motors work then? Should I connect it to the green relay instead of letting it hang forever, since everything works?
I've tracked the green-black wire and it goes to the sunroof motor and both red wires goes to the fuse box, to the same fuse.
