Results 1 to 16 of 16
Thread: 1984 BMW 733i
    Jun 2013
    toledo ohio
    1984 bmw 733i
    1984 BMW 733i
    I have a 1984 BMW 733i that won't start. When the ignition key is turned the starter motor cranks the engine over just fine. I took the fuel line off of the fuel pump and noticed I wasn't getting any fuel. The fuel pump is working just fine. Might the fuel pump relay be bad? I have found a lot of bad information on the location of the fuel pump relay online and am not sure as to where it is located. Does anyone know where it is located? Thanks, Mike
    A side note: I bench tested the fuel pump when I removed it from the car.
    Oct 2008
    Media, Pennsylvania,
    1991 325i
    Verify if the fuel pump is coming on when you crank the engine.
    1991 BMW 325i(Current Daily) (S52)
    I have carburetors, and I'm not afraid to use them!
    There are always other fish (engines) in the sea (Craigslist)
    Life is about enjoying the engine you are sitting behind.
    Jun 2013
    toledo ohio
    1984 bmw 733i
    Quote Originally Posted by Rudolph320i View Post
    Well the fuel pump is not coming on when the engine is cranking. That's what lead me to believe that the relay wasn't working properly. However, now I tried jumping the solid red wire and the green(with violet tracer) wire in the fuel pump relay socket and I'm still not getting power to the pump. I'm not quite sure how to proceed. Any suggestions?
    Oct 2008
    1991 325i
    IF you dont have power at the relay socket, follow the circuit back to see where it could be broken. Another thing to do is check for spark. If you have neither spark nor fuel then I would look to the crank sensor.
    SD, Cali, USA
    1995 M3, 1985 745i , S13 240sx sr20det
    Look in the e23 section there was a thread about it with pics of the relays to check and other stuff
    95 BMW M3 Alpine-
    <GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
    Jun 2013
    toledo ohio
    1984 bmw 733i
    Ok thanks, I'll check it out.
    Zionsville, IN
    93 740i, 84 533i
    Had a similar issue with my 533 Turned out it was the Main Relay. The wires running to the relay became loose. Actually came loose while driving. I thought I had run out of gas. Reconnected the wires, and good to go.
    Black on Black 740i - 10/92 build date, 225,000 miles.
    Delphin on Cherry 533i - 4/84 build date, 136,000 miles
    Black on Black 328i - 3/96 build date, 185,000 miles - Sold
    2008 Porsche Cayenne GTS
    Jun 2013
    toledo ohio
    1984 bmw 733i
    Quote Originally Posted by Avec View Post
    OK thank you guys. However, now I have a new problem. After playing with the relay and the wiring to the fuel pump I now have power to both fuel pumps. I disconnected the fuel line after the inline pump and verified that I was getting fuel. I am also getting spark in the ignition system. If I spray staring fluid into the throttle body I get ignition but the engine will only run for about 10 seconds until the stating fluid is gone. I would assume that the fuel injectors are operating properly at this point right? I'm not quite sure why the engine will not continue to run. Any ideas?
    Oct 2008
    1991 325i
    You may not have proper fuel pressure to keep running.
    Jun 2013
    toledo ohio
    1984 bmw 733i
    I opened up the small valve/filter piece that looks like a hat that is located on the fuel line just before the fuel rail and noticed that there was no liquid fuel present. Might this hat valve be clogged or blocked or might there just not be enough pressure to get fuel to this point?
    Zionsville, IN
    93 740i, 84 533i
    I would saw rear the fuel pressure, but it sounds like zero. Jump the pump relay and test the pressure, or at least are if fuel comes out of the line
    Jun 2013
    toledo ohio
    1984 bmw 733i
    OK I've made some progress. When I crank the engine over I'm getting fuel pumping out of the in-tank fuel pump. At the same time the inline pump is coming on as I can hear it and feel it vibrating. However, while it is running as such it is not pumping any fuel out of it. I took the pump off and ran a fuel line from a gas can and hooked the pump straight to a battery and got fuel to pump out. Does this sound like the pump is not grounded properly and thus not getting proper voltage?
    Oct 2008
    1991 325i
    check voltage at the pump, but sounds like it may be on the way out.
    Jun 2013
    toledo ohio
    1984 bmw 733i
    Ok, new scenario. I now can get the car to start and run if I hook the fuel pump straight to a second battery while a helper is cranking over the engine with the key. Obviously I'm not getting proper voltage to the leads going to the fuel pump. My question now is how do I wire power from under the hood straight to the fuel pump in order to correct this issue?
    Oct 2008
    1991 325i
    you cant just wire power straight to the pump, you need to find out why power isnt getting there.
    Jun 2013
    toledo ohio
    1984 bmw 733i
    OK, any suggestions on how to diagnose that? I'm not the best with electrical.
