Results 1 to 5 of 5
Thread: ► APEX | Inventory Blowout on Select Wheels
    California BAY AREA
    e30 M3, 335d
    In order to make room for new and exciting products, we are clearing some space off our shelves with discounts on select wheels and finishes. Save up to $320 on a set of select ARC-8 or EC-7 wheels through Oct. 31st! Supplies are limited so order yours today! If you have any questions about wheel fitment and you'd like guidance or a recommendation, our BMW Fitment Experts are available at (888) 499-9135 or you can shoot us an email.
    Offer and discounts limited to the wheel sizes and finishes listed below while supplies last. All orders must be completed by October 31, 2014. No backorders or rain checks available.
    EC-7 18x10" ET25
    Applicable for: E9X M3, E46 M3, Z3M, Z4M
    This 18x10” is one of our most popular wheels. It’s the perfect solution for enthusiast looking for a square setup on an E9X M3. This application is a direct bolt on fitment when matched with most 275/35/18 tires, giving the car an aggressive look with its profile 3 concave design. Although aggressive, many track oriented customers have used this size as a square setup for their E46 M3 as well. You’ll also commonly see this size used on the rear of the E46 M3, Z3M and Z4M for staggered fitments.
    EC-7 18x10" ET33
    Applicable for: E9X non-M (Pre-LCI only), E46 M3
    This unique size allows E9X non-M (Pre-LCI) owners to run a 10” rear wheel without having any fitment issues. This rear fitment is becoming increasingly popular and certainly maximizes wheel width in the rear. Furthermore, many E46 M3 customers who would like to run a 10” square fitment, are faced with the challenge of running overly aggressive front camber specs. With that said, the 18x10 ET25 can be quite difficult to fit upfront. This 18x10 ET33 requires less negative camber than the ET25 due to its higher offset, and has the ability to fit up a 285/30/18 tires with the proper suspension.
    EC-7 18x10" ET43
    Applicable for: E9X non-M (pre & post LCI), E46 non-M, E36
    We produced this fitment to accommodate those with an E9X non-M, specifically those with an LCI model sedan looking for the widest rear wheel possible. BMW decided to widen the rear track of the LCI model by 8mm, and this caused some rear fitment issues for customers wanting to run a 10” rear wheel. Our 18x10 ET43 allows all E9X non-M, pre & post LCI models, to run a 10” rear wheel. The 18x10 ET43 also provides E46 non-M owners the ability to run a 10” rear wheel as well, and is used on the front in extreme auto-cross and race applications with suspension modifications. Just like the E46 non-m, this high offset 10” wheel can be found on aggressively modified E36 models when a 285/30/18 tire is being used in competition.
    EC-7 18x9.5" ET43
    Applicable for: E9X non-M (Post LCI), E46 non-M, Z3 non-M, Z4 non-M, E36
    We produced this offset to to be a direct fit on Post-LCI E90 sedans. This wheel also provides e46 non-M owners with an easy-to-fit 9.5” rear wheel as well. That fitment is similar to the non-m model of the Z3, and Z4. The 43mm offset is also ideal on the rear of the E36 where our lower offset wheels result in owners having to roll/flare fenders.
    EC-7 18x9" ET31
    Applicable for: E36, E46 non-M, E46 M3, E9x non-M, Z3M, Z4M
    This EC-7 wheel fitment is a new size that wasn’t produced for the ARC-8’s, and provides a concave face that compliments the modern lines of BMW’s. The 18x9” ET31 is a popular wheel to be used on the front of the E46 M3, E9x non-M, due to it’s flushness with the fender without the need of spacers, while also providing better clearance for coilovers that utilize V-shaped progressive springs. This is the narrowest wheel with Profile 2 concavity. The low offset can be a trickier fit on some applications, but it’s much easier than the 9.5” equivalent.
    EC-7 18x9" ET42
    Applicable for: E36, E46 non-M, E46 M3, E9x non-M, F30, Z3M, Z3 non-M, Z4M, Z4 non-M
    A new rendition of an old fitment, this EC-7 wheel boasts a new spoke design that truly compliments the modern lines of BMW’s. The 18x9” ET42 EC-7 is a great squared fitment for the E46 non-M and E36 chassis due to it’s added width, allowing up to 255/35/18 sized tires. This wheel is gaining popularity for the F30 chassis as a squared track fitment since the EC-7 design flows well with the F30 chassis and is a direct fitment for even stock cars. E9X non-M owners can also use this application for a performance oriented square setup but will require a front spacer.
    ARC-8 18x9" ET42
    A classic wheel for BMW’s that have a long race inspired heritage, this lightweight wheel remains a popular choice for enthusiasts everywhere. The 18x9” ET42 ARC-8 is a great squared fitment for the E46 non-M and E36 chassis due to it’s added width, allowing up to 255/35/18 sized tires. This wheel is also gaining popularity for the F30 chassis as a squared track fitment since due to its lightweight construction. E9X non-M owners can also use this application for a performance oriented square setup.
    ARC-8 18x8.5" ET38 - 18.40lbs - Profile 1 - $279
    A classic wheel for BMW’s that have a long race inspired heritage, this lightweight wheel is one of our most popular sizes. The 18x8.5” ET38 is a great easy to fit wheel on the front of the E36, E46 non-M, E46 M3, E9x non-M, F30, Z3M, Z3 non-M, Z4M, and Z4 non-M cars. Almost every car can fit this wider than stock wheel without issue. This wheel is a popular squared wheel for the E36 and E46 non-M, as well as gaining popularity with the F30 for an easy direct fitment that does not require major fender modifications or additional negative camber. This lightweight wheel has become a track and autocross favorite over the years.
    Save on these Wheels:
    Ordering and Contact
    • Phone: Call (888) 499-9135 EXT. #1 for phone orders.
    • Payment: Credit and Debit Cards: Visa, Mastercard, AMEX, Discover, PayPal. Bank Wire Transfers are also available. Contact us to use a wire transfer for payment on your order.
    • Tax: California customers will be charged 9.00% CA sales tax.
    • Shipping: APEX ships all orders with UPS.
    • APEX Hours:
      Monday thru Friday: 9AM to 5PM PST
      Saturday and Sunday: Closed
    • Warehouse and local pickup: The APEX warehouse is at 7888 Marathon Drive, Unit A, Livermore, CA, 94550 (Map It), (888) 499-9135. This is where you pick up local orders.
    California BAY AREA
    e30 M3, 335d
    Thank you for the inquiries, all PM's have been replied.
    Jan 2002
    North Augusta SC
    Any F-25 X3 fitments? I have 19s now, but looking for 18" alternative for more tire options.
    '95 M3 S54 Track Toy
    '19 X5 40i M-Sport
    '16 Cayman GT4
    ‘23 GR Corolla
    California BAY AREA
    e30 M3, 335d
    Quote Originally Posted by m3bs View Post
    Unfortunately we do not have any specific F-25 X3 fitments available. However, we can check to see if there are any fitments that have similar widths and offsets to what you currently have.
    California BAY AREA
    e30 M3, 335d
    Don't let this chance to save pass you by, for any questions feel free to contact us!
